GVCW - towing capacity 1987 F-350 7.3L diesel
Looking for information regarding the "recommended" towing capacity GVCW
1987 Ford F-350 4x4
4 speed transmission
modifications ...
upgraded to 7.3L turbo diesel
4:10 gears
under/overdrive
lift with upgraded suspension
other ..
Original stock GVWR Range: 6,001 - 10,000 Pounds (6.9L diesel, 3.?? gears)
One post . from Ford recreational 1992 towing guide ..
Stock .. 7.3L w/ manual trans with 410 gears .... 14000 lbs
... i understand weight limit recommendations may be set by the manufacture for various reasons ... trying to get an idea where the max. tow limit might be .. when looking at trailers and fifth wheels some are fairly heavy (e.g. ~14,000 to over ~20,000 lbs) & tow vehicles (e.g. ~3,000 to over ~5,000 lbs)... if loaded truck weight is somewhere around 10,000 lbs (e.g. with camper) then towing capacity might significantly decrease ...
1987 Ford F-350 4x4
modifications ...
4:10 gears
under/overdrive
other ..
keyul
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
19
03-28-2017 03:22 PM
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
03-23-2017 05:54 PM
43tutor2
Toy Hauler Towing; Fifth Wheel & Bumper Pull
07-07-2016 07:47 PM
IcutMetl
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
11-16-2010 10:01 PM
BlueOvalBud
02-05-2010 08:34 PM
