1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
rear rotor removal
Old 02-10-2011, 11:10 AM
fatboywpg's Avatar
fatboywpg
fatboywpg is offline
rear rotor removal
<HR style="COLOR: #d1d1e1; BACKGROUND-COLOR: #d1d1e1" SIZE=1> <!-- / icon and title --><!-- message -->
Hi,
I have a 2006 F250 and noticed that the passenger rear brakes were making noise. I removed the caliper but I'm unable to take the rotor off,as it needs to be replaced. I've sprayed it with WD40 hit it with a mallet and still can't get it off??? any info or direction would be appreciated, I've never had any problems with other brake replacements but this is my first F250 is there anything differ?
thks
fatboywpg
<!-- / message -->
<!-- controls -->
Old 02-10-2011, 11:29 AM
FVA's Avatar
FVA
FVA is offline
Back off the parking brake pads.
They are a separate drum brake and the inside of the rotor acts as the drum.
Old 02-10-2011, 12:21 PM
billybop90's Avatar
billybop90
billybop90 is offline
Originally Posted by FVA
They are a separate drum break and the inside of the rotor acts as the drum.
+1 on this. F series backplates seem like they are notorious for rusting out and Made it somewhat difficult to remove the rotors.
Old 02-10-2011, 12:31 PM
89LX306's Avatar
89LX306
89LX306 is offline
I had to use a hydraulic 3 jaw puller on mine. If you have to end up going that route...be careful. Those rotors will fly when pulled with a puller.
Old 02-10-2011, 01:01 PM
BPofMD's Avatar
BPofMD
BPofMD is offline
Received 1,098 Likes on 998 Posts
Be sure to loosen the parking drum brake. There's a cutout on the back of the assembly - like the way we USED to adjust drum brakes.
Old 02-10-2011, 01:15 PM
mikesmayhem's Avatar
mikesmayhem
mikesmayhem is offline
For mine I ended up using a large maul to bang it off. Several hard wacks to break the seal. I new they were being replaced so if they got damaged it was no big deal.
Old 02-10-2011, 01:49 PM
FVA's Avatar
FVA
FVA is offline
My backing plate was so rusted.......
......1999 in upstate NY, that I had to replace both of the backing plates. Ford only item to the tune of $370- a piece. They come complete with pads,springs, etc. mounted.
Old 02-10-2011, 03:46 PM
fatboywpg's Avatar
fatboywpg
thanks <TABLE cellSpacing=6 cellPadding=0 width="100%" border=0><TBODY><TR><TD noWrap>BPofMD ******** type=text/javascript itxtBad="1"> vbmenu_register("postmenu_9949793", true); *********>
Old-Timer
2005 Ford F-250
</TD><TD width="100%"> </TD></TR></TBODY></TABLE>
I'm going to look at that when I get home from work
runner32
60
10-23-2023 12:54 PM
Mobilecal
6.7L Power Stroke Diesel
08-18-2019 11:25 AM
A/Ox4
Projects
45
04-15-2013 03:45 AM
nastyd
2004 - 2008 F150
57
08-13-2012 07:35 PM
captwfcall
43
11-06-2011 08:06 PM
Quick Reply: rear rotor removal
