68 f100 rear axle seal and bearing replacement - Ford Truck Enthusiasts Forums
Old 02-10-2011, 11:18 AM
68dadto3 68dadto3 is offline
68dadto3 is starting off with a positive reputation.
I need to replace my passenger side rear seal and possibly the bearing. Is this a DIY driveway fix or do I need a hydraulic press for the bearing. Could someone give me a play by play on this job? How many hours? etc....
Old 02-10-2011, 01:39 PM
jeremy sanders jeremy sanders is offline
jeremy sanders is starting off with a positive reputation.
its pretty easy man take ur tire off brake drum an ur axle will have a hole n it there are 4 nuts take nuts off an slide axle out an yes theres a sleve collar that holds plate on an it an bearings r pressd u ought 2 be able handle it
its a pretty simple job dude u ought 2 b able 2 do it
Need help with leaking 1356 transfer case mr1 1987 - 1996 F150 & Larger F-Series Trucks 1 09-10-2016 11:38 PM
2005 f250 rear wheel bearings paynemaster11 1999 to 2016 Super Duty 0 10-27-2015 04:01 PM
E150 rear axle play oldcurmudgeon 1968-2013 Full Size Vans 61 02-04-2014 01:25 PM
97 Expedition rear axle seal mebush 1997-2006 Expedition & Navigator 3 12-01-2005 11:50 PM
Rear Axle Bearing Play Matt Wilson Clutch, Transmission, Differential, Axle & Transfer Case 1 07-21-2005 10:30 PM
Tags
1967, 1972, 68, alxe, axle, bearings, differential, f100, ford, length, rear, replacement, replacing, seal, width
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
