1996 F350 460 MAF? - Ford Truck Enthusiasts Forums
1996 F350 460 MAF?
Old 02-09-2011, 09:00 PM
Kirbys73F100's Avatar
Kirbys73F100 Kirbys73F100 is offline
Kirbys73F100 is gaining momentum as a positive member of FTE.
1996 F350 460 MAF?
Sorry, if this question has been asked before, I searched to no positive avail. I want to know if the 1996 F350 had mass air flow. Also, did it come with OBDII? My brother is shopping for a particular truck: 4 door, long bed, 1996 F350 (maf, obdII) 460 4x4 (dana 60's front and rear) with a C6 auto. Does anyone know if this truck exists? Thanks in advance!
Old 02-09-2011, 09:27 PM
jk89cat jk89cat is offline
jk89cat is starting off with a positive reputation.
over 8500gvw did not require obd2 for 96 97 only under, , i do believe they are mass air though
Old 02-10-2011, 10:27 AM
jokerforever's Avatar
jokerforever jokerforever is offline
jokerforever is gaining momentum as a positive member of FTE.jokerforever is gaining momentum as a positive member of FTE.
No, that truck does not exist.
460 F250/F350s shipped to California and, I think, New Hampshire in 96-97 had MAF because those states had stricter emissions. All other destinations got the same Speed Density setup from prior years. I think I have seen MAF 351 trucks shipped to other parts of the country but that would have to be confirmed by somebody else.
A F350 will have a Dana 60 in the front and the f250 will have a TTB Dana 50 or HD44 according on the GVW. Both will have a Sterling 10.25 in the rear. Dana 60s haven't been in the rear of Ford heavy duty truck since the early 70s. Also, both trucks will have an E4OD unless it was a chassis cab 1-ton or bigger. Some of them, though rare, could still be optioned with a C6. Most still got the OD trans.
But that doesn't mean that you can't find a great truck. Holdout for a Cali MAF F350. As you should know, that will greatly increase your modification options. The E4OD is a great trans. It was basically an electronically controlled C6 with an overdrive added on. What few weaknesses it has are similar to the C6 and are well documented. There are many aftermarket solutions for them. The Sterling is also great. It's a true 1 ton axle with few flaws and a growing aftermarket. I don't know what your attended use for this truck will be but more than likely the major stock components will stand up to almost anything you need.
Old 02-10-2011, 10:52 AM
he's correct after checking out the catalog, the california only trucks were mass air . all others were map
EECIV VS OBDII BWD444 Electrical Systems/Wiring 4 12-30-2016 07:52 PM
EECIV / OBDII BWD444 1987 - 1996 F150 & Larger F-Series Trucks 11 12-27-2016 04:05 PM
Changing camshaft on MAF, OBD-II 300. Unaffiliated Ford Inline Six, 200, 250, 4.9L / 300 5 11-24-2016 03:47 PM
Obd-ii?? mbkatt 1987 - 1996 F150 & Larger F-Series Trucks 10 06-19-2008 07:45 PM
460 EFI Paxton Supercharger Big350 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 10-01-2006 08:54 PM
Tags
1996, 1997, 460, 97, air, density, f250, f350, ford, maf, mass, obdii, speed, ton, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
