Ring and pinion for Dana 44 TTB?
i dont know were ur located but u can call randys ring and pinion or east coast gear supply they are extreamly help full when it comes to these questions. but as far as gears ive always had good luck with Yukon i just orderd 4:56's for my 94 with master install kits for $563 from east coast gear yesterday they did all the resurch for me as well.
you can get "thick" gears but i am pretty sure only in 4:10s. these gears allow you to keep your smaller carrier. or you could buy a nice limited slip for 3:73 and up gears. this will cost more and unless your doin harcore wheeling, i would just track down a 3:73 and larger carrier for your D44
if thats a little confusing the carrier you have now will only fit a 3:73 as its highest number or lowerest gearing with the exception of thick gears. the carrier you need fits >3:73 and higher number/lower ratio gears.
also make sure the gear you order is a reverse cut/ high pinion gear also. the 60s D44s were not high piniona
Caveman2851
11-28-2016 08:55 PM
Forger
06-10-2016 12:05 AM
