How to: 2003 6.0L Serpentine Belt Replacement - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-09-2011, 06:36 PM
HH65cpilot HH65cpilot is offline
HH65cpilot is starting off with a positive reputation.
First off let me tell you that I have no formal mechanical training or very much experience for that matter.
I'm going on a long road trip soon and my 03 F350 6.0L just went over 70K so I thought I would replace the serpentine belt before the trip. Should be easy right? It took me about 2.0 hrs but I did manage to swap the belts out and I thought I would share my lessons learned for any other daring folks who want to tackle this job.
1. Remove upper fan shroud using a small tip screw driver to free the 9 or so clips holding it on.
2. Remove the air filter.
3. Insert a 1/2 inch drive socket wrench into the tension pulley. Use a 2-3 foot cheater bar for extra leverage and rotate the pulley towards the drivers side. While holding the tension pull to the right, reach down with your left hand and flip up the "kick stand" type lever that will keep the tension pulley from tightening the belt back up.
4. Take a long hard look at the belt diagram and visualize that the belt is run sort of like an upside down "c" through the flywheel and fan shaft.
5. Grab your new belt, pinch it together at one end and feed it between the flywheel and the fan shaft from left to right. Now work from the top right to the bottom right pushing the old belt aside and running the new one. Now feed the middle pulleys and then on to the top left and bottom right. No not run the belt over the alternator. Finally, crawl under the truck and push the last loop over the tension pulley.
6. Cut the old belt off.
7. Align the new belt making sure you get each ridge on the belt in each pulley groove. Get all the slack out of the bottom pulleys and move to the top. pinch the excess slack up and over the alternator.
8. Pull up firmly on the remaining slack making sure the belt stays aligned as you pull. You'll hear a click as the "kick stand" releases and tension is applied to the belt.
9. Double check that the belt is properly aligned with each pulley. I have heard that you run the risk of shredding a belt if you are off by even the slightest.
10. Reattach the fan shroud and put the air filter back in.
11. Start the beast and check to make sure everything is working properly.
I have read a few posts on this forum in regards to how to do this but thought I would share my prospective. It not a very fun job but I saved myself about $250. Good luck!
Old 01-24-2013, 12:49 PM
altruego's Avatar
altruego altruego is offline
altruego is starting off with a positive reputation.
This is a great description of replacing the belt. Thanks!
Old 01-24-2013, 02:45 PM
jh818's Avatar
jh818 jh818 is offline
jh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputation
At that high mileage, it would be a good idea to replace the tensioner, too while you have the belt off.
Old 01-24-2013, 04:18 PM
texastech_diesel's Avatar
texastech_diesel texastech_diesel is offline
Disgruntled Texan
texastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputation
Just to change OP's "Step 3" (he won't mind, he hasn't been back since 2011 ) of actually leveraging on the belt tensioner with a breaker bar and trying to set the kickstand at the same time.... just grab the belt with both hands and heave it up and off the alternator, use one of those cheap spring clamps to take the slack out of the belt if you're worried about it flopping around. At the end either reach down and set the kickstand, or just heave the belt back on to the alternator.
Routing of 6.0L serpantine belt with single alt:
Belt tensioner kickstand OFF:
Belt tensioner kickstand ON:
Old 03-27-2016, 05:23 PM
ROKNZRX's Avatar
ROKNZRX ROKNZRX is offline
ROKNZRX is starting off with a positive reputation.
Great post, Thanks!
Man, It has been years since I have posted anything. I am so greatful for all the folks that keep these forums alive.
Thanks for the pictures. My tensioner was shot. Much easier to change out belt with it out of vehicle. Appreciate the tips.
Belt tensioner - what am I missing?! diesel_dan 6.0L Power Stroke Diesel 24 05-28-2015 10:52 AM
5.0 serpentine belt walking off crank pulley 73FOMO Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 7 03-19-2014 06:08 PM
GUIDE: How to remove the Water Pump in a 1990-1997 4.0L OHV V6 Ford Aerostar Lee Binder Aerostar 5 02-19-2014 02:28 PM
Squeeking Belt or Pulleys any suggestions how to narrow it down? 4WheelDriveVan 1997 - 2003 F150 8 12-10-2010 07:30 AM
Serpentine Belt Jumping off the Pulley kinnja Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 09-03-2004 12:27 AM
Tags
2003, 2004, 60, 60l, accessory, belt, diesel, f250, f350, ford, located, pwer, replace, replacement2003, serpentine, stroke, tensioner, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
