vaccum pump removal
Received 3,652 Likes
on
Welcome to FTE.
Remove the serpentine belt. There will be three 10mm bolts to remove along with the 5/16" hose from the pump to the vacuum manifold. R and R the pulley using a pulley puller / installer (may be available at the parts store or they may do it for you). Place the bolts in the new pump before the installation of the pulley. Attach the hose (inspect to see if you need to replace it) to the new pump. Bolt it up. Reinstall the belt.
