You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
We've all seen them. Posts that just make you wonder, WTF was this guy thinking or, was this guy drinking, or did this guy pass 6th grade? I think we need a place to share them, and celebrate together that it wasn't us, this time.
I don't like to embarrass anyone if I can help it, so I suggest we remove the users name and just post the quotes. When you find one, share it here. Unless the stupid post is one of mine.
Found this one today:
Quote:
I just had a macanic set up a key fob for my 06 S.D. Turn the key on the ignition to the on and off setting (with out starting the truck) back and forth at least (5) times and your doors will otomaticly lock and un-lock. When they do, imediatly press your key fob button and it will began to work. It's kind of like setting up a T.V. remote in a way. I only seen it done so please be advised I'm not a perfesional , im only trying to help.
__________________
Folks call me Bill. Why, yes, it is a 6 liter. Your jealousy is showing.
2006 F250 XLT SCLB FX4 4x4 6.0L Auto,Magnaflow Turbo Back (w/CAT),Edge Insight CS,Blue Spring,RhinoLiner,Retrax Cover,Cab Lights Retro-fit,Overhead Console Retro-fit,Bilsteins,Harpooned,C-Betrs,Fumoto,'08 Diff Cover,Upfitters Retro-fit,Coolant Filter,Custom Man Steps,Keystone 2011 Cougar 278RKSWE,2012 Fusion SE
we cut tha main feed lines none going to a injectors when we cut the main feed lines we did it about half way there cause the extra lenght needed cause of the fuel fliter bracket what we did was cut the hard with a tub cuter not dykes or tin snips sliped over the ruber tube over both ends them clamped it down with house claps
I think we've seen this one before, but it's worth seeing again.
i has 80/100 on my lasted truck... and i am pretty sure it lasted a lot more then suggested 100 hours. and i used my truck daily... idk why they would put that.
I can understand this, but barely....
Steve's right, we're all eventually gonna' go ta' hell for this thread!
They'll find it when someone does a search on some key word, like "otomaticly" or some-such.
had an 88 b2, camper cut off, 31-10.50's, 60mph on dirt road, made a 90 degree left, slipped, slided, fishtailed, was 3sptw, and didn't flip till i hit the bottom of ditch, then it popped both dside tires and laid over. luckily my dumb-*** walked away. soon as i figure it out, i'll put up pics.
ok, not sure if this qualifies. It's TECHNICALLY a listing, not a posting. lol. My appologies if this is your ad.
"2005 F.250 TURBO DISEIL
131,000 MILES
LIFTED BIG TIERS RUN GEART LIKES VERY CLEAN
THE INTERIOR IS VERY CLEAN
NEED TO SELL FOR MORE INFO, CALL OR TEXT ,,,,,,,323 ###-#### ABLON ESPAņOL FINANCIES IS AVALIBOL"<!-- START CLTAGS -->
