Intro and a few questions
Hey all,
I've been a poster on FTE for a long time but just recently became infatuated with the idea of converting my old 77F250 4x4 to LP or CNG or whatever alt fuel is the best and I have a few questions
Are there pro/con's to both fuels?
I have CNG at home, can I fuel at home with CNG?
Whats involved in LEGALLY doing a conversion on my old pickup?
Thanks Guys!
Thanks Guys!
Lpg will be the easier of the two. The engine equipment is similar but CNG requires a tank to withstand hi-pressures of 2000-3000psi which are small and of limited capacity, requires an expensive compressor to fill the tank. And if I remember correctly the tank has a limited life. LPG Usally easier to get ahold of. If you want to give up the bed space you can put large tank in the bed (100 gal or so) and with an older vehicle the equipment should be easy to get. As far as legal issues it boils down to Local Authority Having Jurisdiction (Air polution board etc) as to if you can have your local mechanic do the converison or you have to go to a decaded shop.
Thats the high points I have had numerous trucks on LPG and use to do conversions in my driveway till I got older and the computers got more complicated.
I know I have not touched everthing but let me know any questions and I will try to answer them or get the answer for you
Regards
Regards
Thanks for the reply. I live in TX so there are a few LP stations in my area. I don't mind taking up some bed space.
What is involved and where would I source parts? How expensive is this process on an older carburated truck?
Can i expect a mileage increase of is it just cheaper to fill up?
Thanks
Thanks
Start with your local Lp dealer. Most of them are versed in the conversions or know where to send you. If you buy all new equipment it could be anywhere from $1000-$4000 the biggest expense being the tank. If you can find a used tank it would be to your benifit. Depending on how its set up your mpg will remain the same or decrease some. Depending on location (fuel cost, taxes, grants and rebates) your costs should be lower. Older units dont require as much computor support so they are simpler to do. If you plan on Bi-Fuel be sure to get a "dual curve" unit to optimise your timing on LPG.
If you are going Dedicated have you dizzy recurved. How many miles on your engine?
Over all condition of it good compression etc?
