Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 02-09-2011, 02:21 PM
jecsd1 jecsd1 is offline
Garage is empty, add now
jecsd1 is starting off with a positive reputation.
Intro and a few questions
Hey all,
I've been a poster on FTE for a long time but just recently became infatuated with the idea of converting my old 77F250 4x4 to LP or CNG or whatever alt fuel is the best and I have a few questions
Are there pro/con's to both fuels?
I have CNG at home, can I fuel at home with CNG?
Whats involved in LEGALLY doing a conversion on my old pickup?
Thanks Guys!
  #2 (permalink)
Old 02-09-2011, 04:10 PM
gasman6674's Avatar
gasman6674 gasman6674 is offline
1996 Ford F-350
gasman6674 is starting off with a positive reputation.
Lpg will be the easier of the two. The engine equipment is similar but CNG requires a tank to withstand hi-pressures of 2000-3000psi which are small and of limited capacity, requires an expensive compressor to fill the tank. And if I remember correctly the tank has a limited life. LPG Usally easier to get ahold of. If you want to give up the bed space you can put large tank in the bed (100 gal or so) and with an older vehicle the equipment should be easy to get. As far as legal issues it boils down to Local Authority Having Jurisdiction (Air polution board etc) as to if you can have your local mechanic do the converison or you have to go to a decaded shop.
Thats the high points I have had numerous trucks on LPG and use to do conversions in my driveway till I got older and the computers got more complicated.
I know I have not touched everthing but let me know any questions and I will try to answer them or get the answer for you
Regards
__________________
Jim England
Do you have Gas? Propane Execeptional Energy
2012 Escape Ltd FWD, 2005 Explorer Sport Trac 2WD
2004 Escape Ltd FWD, 1996 F350 7.3L CCLB DRW,3" DP,4" Exhaust, Cat Delete, 6637
2012 V-Cross V27FK Super Lite by Forest River TT
  #3 (permalink)
Old 02-09-2011, 06:16 PM
Thanks for the reply. I live in TX so there are a few LP stations in my area. I don't mind taking up some bed space.
What is involved and where would I source parts? How expensive is this process on an older carburated truck?
Can i expect a mileage increase of is it just cheaper to fill up?
Thanks
  #4 (permalink)
Old 02-10-2011, 08:53 AM
gasman6674's Avatar
1996 Ford F-350
Start with your local Lp dealer. Most of them are versed in the conversions or know where to send you. If you buy all new equipment it could be anywhere from $1000-$4000 the biggest expense being the tank. If you can find a used tank it would be to your benifit. Depending on how its set up your mpg will remain the same or decrease some. Depending on location (fuel cost, taxes, grants and rebates) your costs should be lower. Older units dont require as much computor support so they are simpler to do. If you plan on Bi-Fuel be sure to get a "dual curve" unit to optimise your timing on LPG.
If you are going Dedicated have you dizzy recurved. How many miles on your engine?
Over all condition of it good compression etc?
__________________
Jim England
  #5 (permalink)
Old 02-10-2011, 09:19 AM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
CNG is a completely different animal than LPG. The pressure of a CNG system is about 3600psi. The "L" in LPG is liquid, so it behaves physically a lot more like gasoline.
  #6 (permalink)
Old 02-10-2011, 09:27 AM
Bi fuel would be ideal. The engine has about 30K on it since rebuild. Small RV cam. We use it for camping mostly. Sounds like LP would be way easier. Can you refer me to a book or web site with a basic install soni can get a mental picture of how this goes? Thanks again!
Jason
  #7 (permalink)
Old 02-10-2011, 09:59 AM
gasman6674's Avatar
1996 Ford F-350
Check this site out go to the downloads section they have some general drawings to reveiw Downloads
__________________
Jim England
Tags
1987, 1994, 21, class, itasca, mpg, review, sundancer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
