Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Southern Region Alabama, Arkansas, Florida, Georgia, Kentucky, Lousiana, Mississippi, North Carolina, South Carolina, Tennessee and Virginia.
  #1 (permalink)
Old 02-09-2011, 11:28 AM
1997 F-150 1997 F-150 is offline
Garage is empty, add now
1997 F-150 is starting off with a positive reputation.
1997 F-150 steering column repair
It started when my ignition swith would not move from the run postion. I was able to start the truck but to turn it off I had to pull wires. I assumed it was the lock & key cylinder malfunctioning but the new one does the same thing. I have sucessfully pulled apart my column and found I need a new upper shaft spring and shaft bearings but I can not figure out how these parts relate to my ignition switch not turning back. My intention was to find a broken plastic ignition actuator but it seems to be in tack. I have not looked at the lower plastic actuator because it looks like a lot more work. Any suggestions would be appreciated before I go any furthur.
Tags
1997, 96, 97, colium, column, diagrams, disassemble, f150, ford, loose, rebuilder, repair, replacement, souther, steering, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
