Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
- How to Install Car Stereo
Step by step instructions for do-it-yourself repairs
Stereo wiring harness colors
Can someone confirm if this is correct? Appears to be for Excursions at least 2000-02?
2000 Ford Excursion Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Light Green/Violet
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Light Blue/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): Dark Green/Orange
Right Front Speaker Negative Wire (-): White/Light Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
<TABLE dir=ltr border=0 cellSpacing=0 cellPadding=2 width=359><TBODY><TR><TD height=19 width="62%" colSpan=3>Ford Harness connector
</TD><TD height=19 width="19%">
</TD><TD height=19 width="19%">Use
</TD></TR><TR><TD height=19 width="19%">
</TD><TD height=19 width="23%">
</TD></TR><TR><TD height=19 width="19%">Pin
</TD><TD height=19 width="23%">Color
</TD><TD height=19 width="19%">ID
</TD></TR><TR><TD height=19 width="19%">1
</TD><TD height=19 width="23%">Lt Blu/Red
</TD><TD height=19 width="19%">19
</TD><TD height=19 width="19%">Illuination
</TD></TR><TR><TD height=19 width="19%">2
</TD><TD height=19 width="23%">BLK
</TD><TD height=19 width="19%">57
</TD><TD height=19 width="19%">Ground
</TD></TR><TR><TD height=19 width="19%">3
</TD><TD height=19 width="23%">Red/Blk
</TD><TD height=19 width="19%">1000
</TD><TD height=19 width="19%">Ignition
</TD></TR><TR><TD height=19 width="19%">4
</TD><TD height=19 width="19%">blank
</TD></TR><TR><TD height=19 width="19%">5
</TD><TD height=19 width="23%">Org/Red
</TD><TD height=19 width="19%">802
</TD><TD height=19 width="19%">RR Speaker
</TD></TR><TR><TD height=19 width="19%">6
</TD><TD height=19 width="23%">Brn/Pnk
</TD><TD height=19 width="19%">803
</TD></TR><TR><TD height=19 width="19%">7
</TD><TD height=19 width="23%">Wht/Lt Grn
</TD><TD height=19 width="19%">805
</TD><TD height=19 width="19%">RF Speaker
</TD></TR><TR><TD height=19 width="19%">8
</TD><TD height=19 width="23%">Dk Grn/Org
</TD><TD height=19 width="19%">811
</TD></TR><TR><TD height=19 width="19%">9
</TD><TD height=19 width="23%">Lt Grn/Vio
</TD><TD height=19 width="19%">797
</TD><TD height=19 width="19%">Power
</TD></TR><TR><TD height=19 width="19%">10
</TD><TD height=19 width="23%">Blk/Pnl
</TD><TD height=19 width="19%">194
</TD></TR><TR><TD height=19 width="19%">11
</TD><TD height=19 width="23%">Blk/Lt Grn
</TD><TD height=19 width="19%">694
</TD></TR><TR><TD height=19 width="19%">12
</TD><TD height=19 width="23%">Gry/Lt Blu
</TD><TD height=19 width="19%">800
</TD><TD height=19 width="19%">LR Speaker
</TD></TR><TR><TD height=19 width="19%">13
</TD><TD height=19 width="23%">Tan/Yel
</TD><TD height=19 width="19%">801
</TD></TR><TR><TD height=19 width="19%">14
</TD><TD height=19 width="23%">Org/Lt Grn
</TD><TD height=19 width="19%">804
</TD><TD height=19 width="19%">LF Speaker
</TD></TR><TR><TD height=19 width="19%">15
</TD><TD height=19 width="23%">Lt Blu/Wht
</TD><TD height=19 width="19%">813
</TD></TR><TR><TD height=19 width="19%">16
</TD></TR></TBODY></TABLE>
Just leave your RICP (Rear Console Control Panel) plugged in and you may be ok for the Rear speakers. Worse case is some jumpers in the connector of the RICP. Like I said, if you PM me with an e-mial address, I'll send you the wiring diagram.
BTW - The speaker wires are in the Passenger Front Foot well (Right side) and not the Drivers side.
As far as the Steering Wheel controls, Pin 14 of the 20 pin Ford connector ( that plugs into the back of the Ford CD/Radio) goes to the Steering Wheel Controls. It is a Lt Blue/Red wire. Connect it to Key 1 (Red wire or #9 on your radio diagram. You will probably have to ground the other radio Steering Wheel control wire ( #12 or Key 2). According to the manual on my radio (which showed up yesterday), these may need to be reversed to work.
I did power up my radio and check all the functions and everything works. Just need to mount it in the EX
Dw
TXSailor posted this on a different thread, it is what I used when I did my install of an aftermarket head unit a few weeks ago. I found that it matched my Ex (2002 7.3 Limited) perfectly. There is also an additional plug in the back of your stock head unit, my understanding is that is primarily for the rear audio controls, and steering wheel controls, which I do not believe you have in a 2000. My new head unit did not have the ability to have a separate rear zone, so all I used out of that harness was the Lt Blue/Red wire for the steering wheel controls.
icelander_34
11-26-2020 10:39 AM
BAJACRAZY32
11-11-2016 08:09 PM
mkoser
2004 - 2008 F150
13
09-23-2015 03:17 PM
Ace!
09-27-2008 02:23 PM
