1989 F-250 Alternator - Ford Truck Enthusiasts Forums
Old 02-08-2011, 08:28 PM
oldblue89 oldblue89 is offline
oldblue89 is starting off with a positive reputation.
I have a 1989 F-250 Extended Cab 4x4 7.3 IDI non turbo with the zF 5 speed. The truck is not charging (I put my voltage tester on the batteries while it was running to test) so I am assuming the alternator is bad (I put the two new batteries in the truck charged at 12.6 volts, when running they weren't at 14 or anything like they normally should be and were actually at 11.9 after a start-up and short drive. What amperage alternator do I need for this truck (and what amperage alternator was in these trucks from the factory)? Does my truck have an external or internal voltage regulator from the factory? Any recommendations on which alternator I should get?
Thanks
Old 02-08-2011, 08:40 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
I think the factory Alts are 100Amps? Can't remember. I think the one I have in my motorhome is a 165amp (E-350) if I remember correctly on that one.
Man I've been away from diesels for to long....
The voltage regulator is on the passenger side inner fender. It is a small square chrome box.
tecgod13 tecgod13 is offline
tecgod13 is gaining momentum as a positive member of FTE.tecgod13 is gaining momentum as a positive member of FTE.
Should be an external voltage regulator, it will be mounted on the fender well near the passenger side battery. I'd bring the alternator into someplace like Autozone or Advance that will do free testing for you. You might just need a new regulator, I did this summer when mine stopped charging. Voltage regulator is under $20, so before you buy a new alternator, get the present one checked out. Also, the regulator needs to be well grounded, and so check that, and check that the metal plate its mounted too is actually grounded (its mounted to the plastic fenderwell...)
Oh, and I think the alternator might be 75 amp stock? Although a 100 amp version is also out there.
Old 02-08-2011, 09:12 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
just get $15-20 ready and hit the salvage yard for 130a 3g alt with built in regulator and have 100a @ idle charge.
search here for more,and search google etc,for all and more you ever wanted to know,and kiss that old 2g and external regulator business bye bye.
Alternator. Is the stock one enough? Otto396 1999 - 2003 7.3L Power Stroke Diesel 16 05-27-2016 08:57 PM
Alternator replacement brandon.edwards 6.0L Power Stroke Diesel 10 01-30-2014 06:27 PM
Alternator wiring fourbangerford Electrical Systems/Wiring 3 01-08-2014 06:51 AM
1977 F250 Alternator Problems maximumd93 1973 - 1979 F-100 & Larger F-Series Trucks 10 03-11-2013 10:52 AM
Alternator question Chris Guthro 1987 - 1996 F150 & Larger F-Series Trucks 1 09-16-2011 05:20 PM
Tags
100, 1989, 250a, altenator, alternator, amp, external, f250, f350, ford, guide, internal, length, regulator, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
