95 F150 fuel pump replacement
02-08-2011, 04:09 PM
on
I have figgered the problem is the fuel pump...now how do I fix it ?
do I have to drop tank...any help? pix?
02-08-2011, 10:03 PM
You have to drop the tank or remove the bed to replace the fuel pump. What is your issue and how did you determine you need a new fuel pump?
02-09-2011, 02:00 PM
It's a simple job, just drop the tank and replace the pump. The hardest part is disconnecting the lines.
-Rod
therigwelder
10-02-2016 12:34 AM
jcalebw
05-12-2014 06:05 PM
94 F250 supercab
12-21-2011 06:25 AM
david00f150
03-11-2010 07:52 PM
dyoungen
76
01-17-2010 12:11 PM
150 ,
1986 ,
1996 ,
95 ,
96 ,
change ,
f150 ,
ford ,
fuel ,
location ,
pump ,
pumps ,
repair ,
replacement ,
replacment
