95 F150 fuel pump replacement - Ford Truck Enthusiasts Forums
Old 02-08-2011, 05:09 PM
NHtrader NHtrader is offline
NHtrader is starting off with a positive reputation.
I have figgered the problem is the fuel pump...now how do I fix it ?
do I have to drop tank...any help? pix?
Old 02-08-2011, 11:03 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
You have to drop the tank or remove the bed to replace the fuel pump. What is your issue and how did you determine you need a new fuel pump?
Old 02-09-2011, 03:00 PM
White Max's Avatar
White Max White Max is offline
White Max has a good reputation on FTE.White Max has a good reputation on FTE.
It's a simple job, just drop the tank and replace the pump. The hardest part is disconnecting the lines.
-Rod
Fuel pump problems therigwelder 1994.5 - 1997 7.3L Power Stroke Diesel 2 10-02-2016 01:34 AM
fass fuel pump jcalebw 6.0L Power Stroke Diesel 1 05-12-2014 07:05 PM
Fuel pump replacement 94 F250 supercab 1987 - 1996 F150 & Larger F-Series Trucks 12 12-21-2011 07:25 AM
Converting 351w roller block to mechanical fuel pump david00f150 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 12 03-11-2010 08:52 PM
electric fuel pump dyoungen Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 76 01-17-2010 01:11 PM
Tags
150, 1986, 1996, 95, 96, change, f150, ford, fuel, location, pump, pumps, repair, replacement, replacment
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
