Leaking diesel fuel.
I have fuel leaking from my secondary fuel filter housing. It appears to be leaking in-between the side of the filter housing and where the supply lines bolt onto the housing with the 4 bolts. Is there o-rings back there or is it a gasket? Has anyone ever had this problem. It's an 2006 6.0
Intrested to know this too. Was warming the truck up this morning and noticed fuel driping on top of the axle, Popped the hood and I could smell raw fuel, upon further inspection I can see fuel dripping every 5 seconds or so from the right side of the housing below the lines and towards the bottom. Does anyone have a diagram of the housing?
Here is the number for the Regulator cover gasket3C3Z-9C065-AA .
It takes a 27 torx bit to remove the 4 screws from this cover: Page 30: Fuel Supply System
Thanks npccpartsman: Would it be a good Idea to purchase to 3v3z-9T517-AG and upgrade the spring as Well? I am at work and have not had a chance to begin the repair.
It's cheaper because it doesn't contain the cover (unnecessary replacement IMHO) and YES it would be a good time to upgrade. There may also be an updated Navistar part number than what I have posted but they should be able to interchange it.
This is the kit number without the cover: 1854267c94
If you have a Navistar dealership near you try this number: 1843065C98 .
I called International and gave them the part number. The parts guy stated that there system shows all Ford Fuel components to be locked out of there system, and can no longer sale those items. WTF! And to answer the question above in most cases Navistar (international) can proved much better pricing on OE Engine components than the Damn Ford dealership.
