6.0 clutch
If the clutch is still original, it will have the dual-mass flywheel, since it is no longer available. Therefore, replacement will mandate changing up to the single-mass flywheel application. The Ford part number for the clutch kit is 3C3Z-7L596-EA, which includes clutch disc, pressure plate, throwout bearing and pilot bearing. Using this kit, requires changing the flywheel to a single mass style which is Ford part number 3C3Z-6375-BA which also requires changing all ten flywheel to crankshaft bolts which is 3C3Z-6379-CA. Lastly, when doing this repair, ALWAYS change the plastic clutch fork pivot inside the bellhousing which almost always breaks during removal which is F81Z-7B602-AA. Use those part numbers to get your quote for the best prices you can obtain. Here it is, from www.tituswillfordparts.com:
https://www.tituswillfordparts.com/cart/
HOPE THIS HELPS.
HOPE THIS HELPS.
