sync not working - Ford Truck Enthusiasts Forums
sync not working
Old 02-08-2011, 09:20 AM
cdmm151 cdmm151 is offline
cdmm151 is gaining momentum as a positive member of FTE.
sync not working
I have anew issue now with my 2011 F150 FX4. The sync stopped working the day before. I got nothing when I pushed the Media button. No phone, directions,menu. Then it started working for a while yesterday then stopped, Later on it started working now it nothing. Who if any has had this problem, or stopped working altogether and found fix.
Thanks
Old 02-08-2011, 11:14 AM
fz1dave's Avatar
fz1dave fz1dave is offline
Super Duty
fz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud of
I'm guessing you mean 2011?
Since you're losing all functions, I would check for a loose connection in the steering wheel harness.
Old 02-08-2011, 11:17 AM
04XLTRUNNER's Avatar
04XLTRUNNER 04XLTRUNNER is offline
04XLTRUNNER is gaining momentum as a positive member of FTE.04XLTRUNNER is gaining momentum as a positive member of FTE.
I had this problem with mine just after I bought my truck almost 2 years ago. Dealer had to replace my radio. Everything was fine up until about 2 weeks ago and it stopped working again. I ended up having to replace my battery after the hard freeze we had last week and it started working when I reconnected the new battery, guess it needed a hard reset. Try disconnecting your battery for 10 minutes and see if it works right after that.
Old 02-08-2011, 01:49 PM
sorry yes 2011. The stupid thing is working now. we'll see how long
Old 02-08-2011, 02:00 PM
shotgunz's Avatar
shotgunz shotgunz is offline
shotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to all
Rather than disconnect the battery, simply remove the Sync fuse for 2-3 minutes.
This solves about 95% of these type issues.
Obviously it will not solve a true loose connection or hardware fault.
Old 02-08-2011, 07:23 PM
efx4's Avatar
efx4 efx4 is offline
efx4 is gaining momentum as a positive member of FTE.efx4 is gaining momentum as a positive member of FTE.
I need to remember all this advice if I ever encounter any issues.
Old 02-09-2011, 07:13 AM
shotgunz's Avatar
In my experience, Sync works 99.5% of the time - more than I can say for my other electronic devices.
Old 02-09-2011, 08:03 AM
tvsjr tvsjr is offline
tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.
Quote:
Originally Posted by mongoo View Post
35,000 dollars later you have to pull out a fuse.yep same old fords.love my truck but lets be honest its still a ford.i figure around 70,000 miles ill be forced to get a new truck
All the drooling and mouth-breathing wears them out quicker.
Old 02-09-2011, 03:25 PM
Quote:
I have to agree. My sync works great other than the 2 minor issues I had. Connects with my phone with no problems, both ipods work just fine.
no complaints from me
Old 02-09-2011, 03:32 PM
Buck 1 Buck 1 is offline
Buck 1 is a splendid one to beholdBuck 1 is a splendid one to beholdBuck 1 is a splendid one to beholdBuck 1 is a splendid one to beholdBuck 1 is a splendid one to beholdBuck 1 is a splendid one to beholdBuck 1 is a splendid one to behold
I have two Fords: a 2010 Escape and a 2010 F-150. Sync works great in both with no issues.
Old 02-09-2011, 04:40 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
It's made by Microsoft. It is gonna require rebooting from time to time.
Old 02-09-2011, 10:46 PM
jmmec jmmec is offline
jmmec is starting off with a positive reputation.
Today, sync had a bluescreen of death for me... This is the 3rd time it has happened. It might happen when I have a 32GB (no, maybe 64GB - I forget now) flash drive connected; less than 200 songs.
Start truck, turn on radio, sync is dead -- nothing is useable on the radio or on the steering wheel control pads.
Turn off truck.
Unplug USB.
Turn on truck.
Sync comes back to life.
Plug in USB.
All is well.
I'll need to do some googling.... contact sync help desk... sell Microsoft stock.
Old 03-10-2011, 03:28 PM
Volunteers27 Volunteers27 is offline
Volunteers27 is starting off with a positive reputation.
Just bought a 2011 XLT and have had the same issue happen twice. Sync would not respond at all on radio or steering wheel. Phone and Ipod would not engage or show up. Had to shut truck off and restart to get it working. It's a warranty issue but still frustrating.
Old 03-15-2011, 08:08 PM
ratucker3's Avatar
ratucker3 ratucker3 is offline
ratucker3 is starting off with a positive reputation.
2011 XLT Sync
Ditto for me.....I have new '11 F150 XLT, 5.0 with Sync......worked great first day........since then Occasionally it will drop the phone. I noticed this after a two or three minute stop (shutting down and removing key) like going inside store and getting coffee.....then I get back into cab and sync may or may not boot up completely. I have noticed that if I shut down completely & restart, most of time everything comes up ok.
Question: do I need to download updates from the syncmyride.com site and install?
I've never experienced this on other brands I've had with bluetooth phone.
IMHO truck is really teriffic despite this minor inconvenience!
thanks for review, ratucker3
Old 03-16-2011, 06:55 AM
shotgunz's Avatar
Run the status checker at Syncmyride.com. If there updates, it will upload them to a USB. Follow the instructions (TO THE LETTER).
I suspect, however, the issue with dropping the BT connection is your phone (BT phonebook transfer). try turning it off and see if it works better.
Sync just stopped working jimmysb7377 Ford In-Vehicle Tech 13 02-11-2016 06:53 PM
Sync has stopped working Doc 2009 - 2014 F150 13 11-16-2015 10:34 PM
Sync & Samsung Galaxy S3 Connection Issue Jeremiah Lee 2009 - 2014 F150 2 02-22-2014 10:08 AM
Sync button not working winginit 1999 to 2016 Super Duty 16 01-24-2014 12:27 PM
Sync chapfr 6.7L Power Stroke Diesel 9 03-17-2012 04:37 PM
Tags
09, 150, 2001, 2009, battery, disconnecting, f150, f250, ford, forum, fuse, location, problem, start, sync, taurus, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
