Oil smoke on new V10
#46
Originally posted by Fredvon4
Who ever had the PVC idea may be on to a possible culprit and I have not taken the time to look closely at the vent circuit to see if there is a designed low area that oil could pool and be sucked into the intake. Folks, there are absolutely only four ways for oil to get combusted. (1) Past three sets of rings. (2) Past the valve guide seal. (3) Past the head gasket (real bad news). (4) Past the intake valve from the egr or pvc circuits.
The problem is, because I put in only 6qts last time, I have not been able to reproduce the problem even when trying. And before, it was easy to do it if I wanted.
Weird... is the timing chain sitting in oil and spinning it up into the valve cover? Sounds like a long strange trip... Way too much oil on the cylinder walls, and after letting it sit the oil pools on top of the piston?
I think because of the 10 cylinders, and the fact that we need a balancing shaft to keep it right, there is an intermittent vacuum in the crankcase. The PCV may pulse, and if you catch it just right, it might actually blow oil out the PCV breather. In a V8, you have all pistons going in the right direction so crankcase pressure/vacuum is constant (given no blow-by). With a V10, there is always one or two pistons going in a slightly different direction and the PCV pressure fluctates. Haven't checked it yet, but I'm sure it does. Maybe it's related?
You can tell, I'm grasping at straws at this point...
ak
Kenneth Kyler
03-21-2016 12:05 AM
TobyJ96
11-24-2014 03:23 PM
