5.0L Coyote 5.0l Ford OHC Coyote engine for 2011+
Magnaflow on 5.0
Old 07-06-2011, 04:13 AM
svt2205's Avatar
svt2205
svt2205 is offline
Magnaflow on 5.0
Well I installed my new Magnaflow cat back, 15000 SI/SO on my 11 5.0. It sounds nice when you get on it, but has no tone when idling. I'm thinking that I will need to replace the front pipe which has the resonator on it. Anyone know of a source for this pipe? I will likely visit a local exhaust shop and see what they can make up for me.
Anyone looking to do exhaust on these trucks should look at replacing the resonator too.<!-- google_ad_section_end -->
Old 07-06-2011, 10:17 PM
640 CI Aluminum FORD's Avatar
640 CI Aluminum FORD is offline
Did you install it yourself? I called the muffler shop a couple of days ago to see about having a True Duel Borla set up put on my 5.0L and they told me that they cut the reso pipe off these trucks when to put aftermarket mufflers on them. I suppose all muffler shops do things differently though.
Old 07-07-2011, 05:05 AM
svt2205's Avatar
svt2205
svt2205 is offline
Sounds like the muffler shop you are talking to is building the exhaust system vs installing an off the shelf cat-back system. I do all of my own work and installing this system was super easy. I just would have liked to have had the option to remove the resonator.
Old 12-30-2011, 09:34 PM
Gary Atsma's Avatar
Gary Atsma
Gary Atsma is offline
Unless you've already done so, the resonator should be replaced with a 3" pipe so the whole system will be 3", as the Y-pipe up to the front joint with the resonator is also 3".
Just so you know, Flowmaster replaces the resonator with a 3" pipe in every system for late Ford trucks, replacing everything from the Y-pipe on back with an all-3" system for better flow.
Old 12-31-2011, 06:06 PM
Boss5.0's Avatar
Boss5.0
Boss5.0 is offline
Ditto........
Justin03PSD
2009 - 2014 F150
02-09-2017 11:24 AM
Bigred1995
1999 to 2016 Super Duty
04-14-2015 09:09 PM
Beau Bo
04-04-2014 08:16 AM
Boss949
2009 - 2014 F150
02-03-2013 07:07 AM
Pool Runner
2009 - 2014 F150
03-21-2012 04:51 PM
Quick Reply: Magnaflow on 5.0
