Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 02-07-2011, 02:00 PM
mac06gt mac06gt is offline
Garage is empty, add now
mac06gt is starting off with a positive reputation.
Lightning engine swap into Excursion
Looking for a little help on this engine swap. Will the excursion 5.4L 4x4 transmission bolt u to the lightning engine? Do I need any thing other than the ecm, wiring harness to make this swap? The current 5.4L is very tired and since the truck os lifted 3" with 35" tires she is a real pig. Any help would be very appretiated.
Thanks, Mac
  #2 (permalink)
Old 02-07-2011, 07:26 PM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
1999 Ford F-250
My Garage
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
I don't believe the trans in your 5.4L Excursion has the same innards found in the 7.3L diesel 4R100's or the Gen 2 Lightning 4R100's. And if I'm correct, and the innards are different, the Lightning engine will make quick work of the innards of your Excursion transmission.
The only difference between the diesel 4R100 and the Lightning 4R100 is the bell housing mounts. They both share the beefed up (compared to the other 4R100's in other vehicles) internals.
Hopefully Mark Kovalsky will see this thread and add his extensive knowledge to the discussion.
Stewart
__________________
The Brotherhood of FTE <-click the link
1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft
1999 PSD F250 SC 4x4: 38R, Stage 2's, T-500, JW trans, Live Tuned, lotsa Riffraff stuff
2000 PSD Excursion 4x4: 38R, JW trans, F5, MBRP, AFE, OBA and Pre-Pump, V & B codes
Never Fry Bacon NAKED!
  #3 (permalink)
Old 02-07-2011, 09:20 PM
travis182008 travis182008 is offline
travis182008 is starting off with a positive reputation.
aaaaaaaaaaaaaaaaaaaaaaaaaa
  #4 (permalink)
  #5 (permalink)
Old 02-07-2011, 09:32 PM
EXCURSIONATOR1's Avatar
EXCURSIONATOR1 EXCURSIONATOR1 is offline
EXCURSIONATOR1 is gaining momentum as a positive member of FTE.
What kind of post is that?spam?
That would be a great swap. Get the highway fuel mileage of the 5.4 and the big torque of instant boost.
  #6 (permalink)
Old 02-08-2011, 08:33 PM
phil6608's Avatar
phil6608 phil6608 is offline
phil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant future
Quote:
Thanks, Mac
The trans will bolt up.
You can put a performance valve-body in the tranny to help it last longer. But there are guys running the L motor on a 4r70 tranny that have lasted longer then I ever thought they would. 4r70 is a lot weaker then the 4r100.
A lot of it depends on how you drive it too.
You do not need the ECM.
Just get a custom tune for the computer that's in your truck now.
What gears are you running with the 35" tires?
__________________
( Phil )2003 SuperCrew: JLP Built Lightning block/Stage 3 heads and cams.
L-conversion/Kenne Bell upgrade blower at 16PSI/BTS,4R100 tranny/100 shot nitrous.
594HP/620TQ Without the Nitrous 1.68 60' time/11.76 @ 116.17 with the 100 shot.
Join the the Delaware Chapter, HERE
  #7 (permalink)
Old 02-08-2011, 09:10 PM
Stewart_H's Avatar
1999 Ford F-250
My Garage
Quote:
Shut up! Seriously, Phil?
Wow brother, just wow!
My bothers V6 Mustang ate a spring in his 4R75....errr, no, it was a 4R70 because his Mustang wasn't that new...anyway, I had to fix his trans for him when he busted the one-two shift spring.
I'd hate to think about how bad an L would punish that trans, LOL!
You're right tho, a lot of it does come down to the driver. That lift and tire combo aint gonna help the OP tho!
Stewart
__________________
  #8 (permalink)
Old 02-12-2011, 02:29 AM
STOFFERJ STOFFERJ is offline
STOFFERJ is starting off with a positive reputation.
I'm pushing 15# thru a stock 4r70, a astock 4r100 with a valve body will be fine unless he's WOT all the time...
x2 on the gears with those 35's
  #9 (permalink)
Old 02-16-2011, 07:14 PM
Just trying to get all the parts but need a little help. Here is what I figure I will need:
1-Engine complete lift out w/ trans
2-fuel pump assembly
3-intercooler heat exchanger
4-intercooler overflow tank
If I buy a tuner with lightning tune can I just upload that tune to my current ecm?
  #10 (permalink)
Old 02-17-2011, 01:50 AM
phil6608's Avatar
You need a custom tune.
If your truck has a 4r100 , you don't need a tranny!
If not and you want to swap in the motor and tranny. Just get the computer from the donor truck and you wont need a tune.
This is a list of parts needed when doing a intake-assembly swap.
http://www.madenterprise.com/catalog/scparts.htm
You may not need every part on here. It depends on what all comes with the L motor you get.
__________________
  #11 (permalink)
Old 02-17-2011, 02:08 AM
x2 on the list...
also watch the hood as some of the F-250 / F-350 swap owners have found out that the eaton will rub on the hood without a lil' massaging
  #12 (permalink)
Old 02-17-2011, 06:49 AM
The donar truck was a front crash so the ECM was destroyed. Is the ECM identical out of my truck!
  #13 (permalink)
Old 02-17-2011, 07:47 AM
phil6608's Avatar
You computer will have no problem being custom tuned to run the motor.
__________________
  #14 (permalink)
Old 02-18-2011, 11:33 AM
Does any one want to sell their stock intercooler heat exchanger or overflow tank? I can always buy the good stuff aftermarket but really do not want to spend $700.00 on these items since the excursion will never see the drag strip!!
  #15 (permalink)
Old 02-18-2011, 12:02 PM
phil6608's Avatar
Shop around on the Lightning sites.
A stock heat exchanger gos for about 100 bucks.
Gen 2 Parts - Lightning Forum | LightningRodder.com
Gen 2 Parts For Sale - NLOC Classified Section
And this guy can get you new factory parts for about the best price I know of. His name is Mike. MADENTERPRISE
__________________
Tags
99, atlanta, computer, davidson, ecm, econoline, engine, excursion, f150, ford, harley, harness, lightning, motor, shops, swap, tuning, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
