2010 F250 front bumper has rust already!
My front bumper is discolored on the inside corners around the tow hooks and the fog lights. I'm in Ohio and we use alot of salt but I've never seen a new bumper rust that quickly. At this point it's not pitted and would rub off with chrome polish but I'm sure it would just come back again. It should be covered under warranty, I haven't been to the dealer yet. Just wondering if this is an isolated case or if anyone else has had the same problem?
Its a complaint that I have also. Have a 3mo old 2011 F250 and have the same problem with 2500 miles on it. I have cleaned it off and it comes right back. It seems that the chrome must be real thin in this area or perhaps missing on the rear side where you can't see it. I am going to see the dealer next month for my first oil change and will bring it to their attention then. My concern is that it will show serious rust in a short time.
Same here - 2011 F-350 delivered in July 2010 (about 7,500 miles on it now) - have had it in snow/salt for about three months (central NY) and the front bumper has rust around the plastic footpad directly below the hood opening and on the inside corners by the hooks. Came on here to see how many other people have been having this problem before I take it to the dealer. I have a 2006 F-350 that I plow with and there's no rust at all on the bumpers (except on the back in a spot where I backed into something).
2011 F-350 Bumper Rust
I have a 2011 F-350 w/6,000 miles, purchased Sep 2010. I noticed discoloration on the left side of the rear bumper. Upon closer loook I saw rust spots coming thru and more rust on the inside edge (that faces forward). It has not been exposed to anything that would cause this. Went to the local Ford dealer. They took pictures, submitted them immediately to Ford and received a reply within minutes. The answer? "Road debris caused it, nothing we can do about it". The folks at the dealer even disagreed but apparently when Ford HQ's made their decision it was final. Road debris does not cause discoloration - only extreme heat or a bad chroming process does. I looked in the warranty booklet and called the Ford Customer Relations Center (800-392-3673) and was given the same answer. My next step is to contact the Better Business Bureau Auto Line that is also in the booklet (800-955-5100). I'll let you know how that works.
My 2010 F350 is doing the same thing, bought it new in October 2010, it has 10K miles now. Looks like the same problem is occuring on GM trucks:
http://www.truckforums.com/forum/showthread.php?t=15532
GM customer service is posting in this thread and is replacing the bumpers on these trucks at no cost. Ford?? What's up??
SAME HERE !!
Well guys I also have a new F150. 2010 purchased in August. 10,000 miles my rear bumper and front hooks are rusting. I was able to remove the rust using some clay bar, but I'm sure it will come back. There are small pits now where the rust was. I waxed the bumpers and hooks a couple times, but Ford needs to know they have a real problem and take care of it. This is my first Ford vehicle, always been a GM guy, but love the look of the Ford truck so I thought I'd try one. I'm not liking this!
