203 Degree Thermostat
  #31
Old 02-14-2011, 05:51 AM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
Originally Posted by DIESELSITE
I hope you mean your changing out pumps to 95s in order to use those stats. What you do in your own truck is your business and I understand people have the right to make their own choices, but I hope the customer knows he's getting the wrong stat if not.
And, don't get me wrong, I honestly don't care that you do or dont run our stat, but people reading your post need to understand why we made the new style, otherwise they could have just bought one at an auto parts store.
More than 1 guy has lost an engine due to using the IH stat in a 96 up water pump. It doesn't properly divert coolant flow and will cause uneven heat distribution in the block.
Another note: I publicly battled a member on one of the boards for years with him constantly telling all that would listen about loosing several engines due to him running the 203 stat. It was in fact a napa 203. He didn't know there was a difference. So, I hate seeing ANYONE get the wrong stat as when they cause an issue, they will assume all 203s are created equal.
Bob
What I meant by using Napa Stats in Customers truck is using the correct application stat for the truck. Whether is a short stem, long stem or a chevy half ton. I was refering to reliability issue Jim was having with aftermarket thermostats. I converted my truck to the older water pump so I could buy a stat over the counter. I have not coverted any customers trucks. Most of them don't want anything more than a stock truck and they don't have the parts laying around for the conversion(heater hose fitting). You are correct that if I was just throwing the napa 203 stat in every PSD I was working on I would have major problems!
  #32
Old 02-14-2011, 06:07 AM
DZL JIM's Avatar
DZL JIM
DZL JIM is offline
PREMIUM SPONSOR
Originally Posted by Muktown
I don't understand how you guys are seeing your trucks warm up faster with a different thermostat. The thermostat is closed until the engine reaches operating temp so whether it opens at 195 or 203 it still takes just as long to get to that temp
IMO, it's not a matter of it being 203° in particular, I just feel the DS stat works like it's supposed to and the other ones were crap and did not. When the stat fails and opens slightly allowing coolant by, the truck will never heat up.
FWIW I put the IH pump and IH 203° stat in my '96 maybe 8 years ago and it still works perfectly today. Again, probably not the fact it's a 203°, but it's a good quality stat and still does it's job.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
  #33
Old 02-14-2011, 10:09 AM
Talyn's Avatar
Talyn
Talyn is offline
I've noticed T-stats are not what they used to be as well.
As for the temp rating, thats the rating that the t-stat is supposed to keep the engine. Not necessarily when it should open.
The t-stat will start opening way before that, otherwise you'd get the old fluctuation thing where the temp gauges keeps pegging both ways cause the t-stat is opening and closing so much.
They are pretty neat.
Play with one in a frying pan and with a lighter or torch.
It's just a liquid medium like wax inside that when it heats it forces the t-stat to open.
  #34
Old 02-14-2011, 10:53 AM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Originally Posted by Major Marvin
Since I live in an area that gets very hot and very cold, will the 203* Stat be to hot for the hot high desert near Santa Fe, NM?
Originally Posted by IDMooseMan
I see days with 100+ temps on a regular basis during the summer months with even more days of 90+ temps. I've had no problems with overheating.
My truck came from the factory with the Super Cooling Package and I'm still running with the OEM fan.
I have the 203* thermostat from DS, and also see days with 100+ temps during most of the time here in my country and as MooseMan I´ve had no problems with overheating, the gauge is in the middle betweeen the R and M (NORMAL) so I think you wont have any troubles Major Marvin.
  #35
Old 02-14-2011, 01:04 PM
Talyn's Avatar
Talyn
Talyn is offline
I see 210-215 with my 203 in the Tennessee heat on the highway.
Mine is bad though. It doesn't work so good in the winter.
john jamieson
12-01-2016 06:52 AM
GraphicRabbit
07-19-2015 10:41 PM
Bowie
07-15-2015 03:37 PM
northwindone
Modular V10 (6.8l)
03-12-2013 10:05 AM
POPAJON
11-21-2012 08:42 PM
Quick Reply: 203 Degree Thermostat
