Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Crossovers
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
  #1 (permalink)
Old 02-07-2011, 09:31 AM
Azguy54 Azguy54 is offline
Garage is empty, add now
Azguy54 is starting off with a positive reputation.
"Road" noise?
2009 Edge SEL had developes a "growl" in the rear end. Sound is akin to the sound from aggressive tires, mudders and the like. If you were to hold a screwdriver aganst the tire treads and spin the tire faster and faster, that is what it sounds like. I replaced all four tires yesterday with new Michelins of the same size and model. Sound is still there. Not a harsh metal on metal sound and doesn't change when cornering. It does "speed" up and get louder the faster you drive. Starts being noticeble around 25 to 30 mph. At freeway speeds it is VERY noticeable. Vehicle has been a great one until this started a couple of months ago. Was very quiet, then they rotated the tires, and it was there. Hence the reason for thinking it was the tires. But now all the tires are new, high quality Michelins, and it is still there. Any ideas?
__________________
George
'68 F100
'01 F150
'97 Aerostar
  #2 (permalink)
Old 02-08-2011, 05:23 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
Who is "they" that rotated the tires?
Still under warranty?
Now if you are so unfortunate as to be on your own with this fine jewel, take it out and run it up for 10-15 min, then check the temperature of the hubs, and any other moving component in the drive train from the wheels in.
A great difference in temp. from one side to the other will tell you the tale.
  #3 (permalink)
Old 02-21-2011, 01:21 PM
Newedgeowner Newedgeowner is offline
Newedgeowner is starting off with a positive reputation.
Rear growl
I just test drove an o7 and I heard the same thing. Its the wheel bearing/hub. It got replaced at 23,000 miles. Its a recall. See if yours is on a recall. The edge has 42000 on it and now the back one is gone bad.
Tags
97, f150, ford, mudders, noise, road, sound, tires, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
