What mods do you wish you hadn't done?
#61
#62
It has been my experience in life that some folks follow directions without regard for anything else...including common sense. Whoever makes these fans and coolers find it most expedient (read, profitable) to make the installation of their product very simple. Unfortunately "simple" is usually not the best way...but given clear instructions even a monkey could attach a pull tie.
#63
#65
First of all, I wish I had done it right the first time! Or at least had a plan to begin with.
I second you John. I put in the Volare then did an engine swap. Couldn't get that engine in so tried an '86 5.0; needed a new oil pan for clearance and oh look it doesn't have the indention for the dip stick. All that with the fact that since it is a '52 so there is even less room for important things like headers. I couldn't afford a MII suspension at the time though.
Latest thing I wish I hadn't done is channel the cab. What a pain! I thought a z-ing the frame would be too dificult but his is rediculous. The more darkside I go the more I can't wait to do my '41 which will be close to stock.
As I read about the exhaust I took a trip down memory lane, driving though the country with the 390 growling along. Had glass packs with a 2-1/4" head pipes and 2" out the back.
Now I'm heading towards the quiet side too as we have holigans behind us that drive all of us neighbors crazy reving up at all times in the night. I've heard pointing the tips at the same spot on the ground does a lot as far as cancelling each other out. Never tried it as I never wanted to cancel the noise out before.
#67
#68
Macs Antique Auto parts "original" style headliner (cardboard)!
They sent me 2 lower trims, one that was way short and one that was way long (minor compared to the rest of the issues - but they have a finish edge, so can not be modified reasonably).
The headliner was 1/4" too wide and so after an hour of very very carefully trying to wedge it in, it creased right in the middle in the back (I hid most of that by putting in a dome light).
The front edge of the left and right panels does not come close to matching the original Ford channel. So I have bare metal / insulation showing.
The holes were completely random places (instructions say to "make new holes in the sheet metal" - bs, they could have done a decent job of matching) - well trying to very carefully drill a new hole blindly I slipped and ran the drill head through the material in a spot.
The rear window (1948) is slightly smaller than the cutout on the panels, so I have bare metal showing.
The bottom pieces appear to be 1/2" too wide, so while the top and upper sides sit in front of the frame, the bottom sits in the frame and doesn't line up with the rest of the pieces.
The bottom pieces are short - there is 3/8" of gap at the bottom (assume I put carpet under my gas tank? and the black hole pocket at the cab is still exposed for cruft to get lost in) and they do not sit in front of the frame at the top - so no way to fasten it... have to pray rely on sprung tight to stay.
The bottom pieces have several cutouts (universal to 48-52), but that leaves gaps and visible insulation along the gas tank top.
The bottom pieces have a funky extra cutout IN THE MIDDLE of nowhere that leaves insulation showing at the top. (really looks tacky - makes me think of low quality cheap Chinese)
I find it kind of tacky that it is 5 pieces when a very large portion of it could have been done in 1 piece (granted it is as Henry did it, but for the look and money I'll redo it myself when it gets damaged)
I'll be glad to edit with pictures later, but on a scale of 0-5, I would give this a 0.5, the only reason it gets that is because I didn't have to spend a month fiddling with making my own (lots of labor). I bought it because I want to spend more time driving and less wrenching, but word of caution, this is one you go ABS on or at the very least a different supplier. I have other issues with this headliner, but my post is already way too long and I'm not a ranter :P
#69
Doc
32
03-29-2011 06:37 AM
scottfreeman
13
09-20-2007 09:34 AM
