Generator to alternator conversion... - Ford Truck Enthusiasts Forums
Old 02-06-2011, 10:58 PM
California Codfish's Avatar
California Codfish California Codfish is offline
California Codfish is starting off with a positive reputation.
Have any of you guys done a generator to alternator conversion on an early 60's f100? I am attempting it on my 63 and from what I can find I just need an alternator and a voltage regulator? is it that easy or am I missing something that is gonna leave me up the creek?
Thanks guys, I really appreciate the good advice I get from this forum!!
Old 02-06-2011, 11:15 PM
Bill W's Avatar
Bill W Bill W is offline
Bill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputation
here you go....
GM current for your Ford
Old 02-07-2011, 12:34 AM
63' f100 63' f100 is offline
63' f100 is starting off with a positive reputation.
I did the exact same conversion on my 1963 f100 4x4. Its very very easy to do. Just build the bracket as they instructed. Just take the positive cable that goes to the current voltage regulator (its the thickest wire, I believe it's yellow, it may have a black stripe i don't recall) and attach it to the stud that is on the alternator. There is absolutely no need what-so-ever for the old voltage regulator. Just take it off and throw it away.
Buy a Delco 10si 63 amp alternator. It has an internal regulator, so you do not need to buy a new regulator for it. It is literally as simple as connecting the positive wire to the alternator and jumping the #2 terminal to the positive stud on the alternator. I didn't worry about trying to hook up the GEN light in the dash, therefore rendering the #1 terminal useless.
If you just build the bracket as shown on that web site, you will discover a significant flaw, and that is that it doesn't allow you to apply tension to the belt. I solved this by using the old belt tensioner. (its the long piece of metal that is about 8'' or so long that has is a long cut to allow you to adjust the position of the original generator) What I did was I took a piece of angle iron and bolted it to the bottom side of the front engine mount. (you will have to drill holes) and then bolted the old belt tensioner thing to the angle iron. This will allow you to bolt the new alternator to it.
this is a thread i posted, it may be of some help.
http://www.ford-trucks.com/forums/10...lternator.html
If you want a picture of what I did, let me know and I will try to get one up.
Old 12-08-2011, 02:16 PM
cashaden's Avatar
cashaden cashaden is offline
cashaden is starting off with a positive reputation.
Hey 63', are you still willing to take a picture of your setup? Unfortunately it looks like the linked site for the alt swap is now defunct.
Old 12-09-2011, 04:56 PM
bunchoftrucks's Avatar
bunchoftrucks bunchoftrucks is offline
bunchoftrucks is starting off with a positive reputation.
I looked too nothing but ads....
Old 11-25-2012, 05:09 PM
Ianmattf100 Ianmattf100 is offline
Ianmattf100 is starting off with a positive reputation.
I am looking to do this too. I have the new delco and my current gen is still in my truck and TOAST,
Old 11-27-2012, 09:33 PM
rustywheel68 rustywheel68 is offline
rustywheel68 is starting off with a positive reputation.
Quote:
why would anyone put a 63-amp Delco in their truck when you could do a 100 or 130-amp Ford 3G just as easily?
Old 11-27-2012, 09:47 PM
Hey rusty can you post a link of the 3G you are talking about? thanks
Old 11-27-2012, 10:00 PM
http://www.ford-trucks.com/forums/94...g-upgrade.html
Old 11-27-2012, 10:11 PM
Shadowrider123 Shadowrider123 is offline
Shadowrider123 is starting off with a positive reputation.
Summit Racing sells a 100a GM 1-wire in a Ford case.
I dont know anything about it, I just noticed it one day while surfing.
I did the 3g, but the cost is about twice as the 1-wire.
Old 12-04-2012, 05:58 PM
P38fighter P38fighter is offline
P38fighter is gaining momentum as a positive member of FTE.
see photo 2 in my album for my alternator set up. The adjusting bar is from Speedway and was a direct bolt in. Part # 916-67915GS - $8
Old 12-04-2012, 07:18 PM
I got it fixed up nice already. Thanks you for the help. I hd to use a double v-groove from pully on the alt and it lined up perfect and has been running very well.
1956 Ford Alternator Rusty_S Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 10 01-13-2017 11:08 AM
Alternator it is... Bowsandovals 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 07-12-2016 08:48 PM
51 F1 po 12v conversion baldmustang 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 08-01-2014 08:41 PM
1959 292 generator to alternator converstion jd$ 1957 - 1960 F100 & Larger F-Series Trucks 5 04-19-2014 02:51 PM
6 volt generator to alternator conversion CFDLT Flathead V8 & Flathead 6 0 10-12-2010 12:03 AM
Tags
10si, 1963, 63, alternator, conversion, diesel, doesnt, f100, flathead, ford, generator, gm, kit, line, mounting, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
