Vacuum in my gas tank - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 02-06-2011, 09:36 PM
Dutter's Avatar
Dutter Dutter is offline
Dutter is starting off with a positive reputation.
The last two time i put in gas i herd this air sucking noise comin from my tank which can only mean one thing. I have a vacuum in there, but what and were do i check, i do a lot of mudding so maybe i clogged the release valve i also hear something clunking under neather me when i hit a bump but idk if that related or not
Old 02-07-2011, 08:39 AM
pawpaw pawpaw is offline
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
The vapor recovery system applys a negative pressure to the gas tank, so that it can pull & store the fumes into the charcoal canister for use in starting & running the engine.
SO, if you don't have any vapor system trouble codes, or aren't having engine stalls, what your hearing when removing the gas cap, is likely normal.
If your having engine stalls after driving 10-20 miles, suspect an actng out vapor recovery system, or a faulty gas cap not properly venting the tank.
Not sure about the clunk, maybe time to crawl underneath & have a look-see!!!!
Old 02-07-2011, 09:59 AM
Dutter's Avatar
Alright yeah ill take a look see. But my truck dus sometimes stall when its cold but thats becasue i have my IAC valve unpluged because its fried
Gas Cap Shadowrider123 1961 - 1966 F-100 & Larger F-Series Trucks 4 08-09-2014 04:25 PM
Gas cap hickory1991 1973 - 1979 F-100 & Larger F-Series Trucks 6 07-02-2014 09:27 AM
Fuel Tank Vents glovemeister 1994.5 - 1997 7.3L Power Stroke Diesel 14 09-10-2013 06:36 AM
gas filler tube issues... i think? brunovidal Ford Inline Six, 200, 250, 4.9L / 300 2 02-23-2008 09:20 PM
help with fuel vacuum line! rebel_ford4x4 Fuel Injection, Carburetion & Fuel System 2 06-09-2004 09:35 AM
Tags
1999, 99, back, expedition, f150, f250, ford, fuel, gas, noise, ranger, seriou, sucking, tank, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
