1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Diehard Gold Battery ?
Old 02-06-2011, 08:15 PM
scottiebe's Avatar
scottiebe
scottiebe is offline
so just recently bought 2 diehard golds (120.00 each) and started to replace, i started on the d side for whatever reason, and the posts on the new bat are smaller.....i bought shims and that didnt work, so i bought new cable ends and same thing couldnt clamp them down good enough was able to "make" shims work with new cable ends. havent done other side not sure what to do about the big azz positive cable. has anyone else run into this prob with small battery posts, just wonder if im better off taking back 2nd bat to find one with bigger posts? any thoughts or info?
thanks
Old 02-06-2011, 10:55 PM
DAVE67FD's Avatar
DAVE67FD
DAVE67FD is offline
All automotive batteries are manufactured with the same size posts. The Positive and Negitive posts are different in size though. Are you sure the ends you bought were the correct ones? Or maybe the cables are worn or have been overcleaned. Batts could be factory defect but would be a first that i have heard.
Old 02-07-2011, 01:57 PM
fireman28's Avatar
fireman28
fireman28 is offline
Something is odd there. I just Put 2 new ones in my truck 2 weeks ago and no issues. Post were same as old ones. You may have gotten a bad battery or put a positive terminal on the ground cable. just a thought.
Old 02-07-2011, 05:58 PM
scottiebe's Avatar
scottiebe
i have never had an issue like this, but i found it odd that the parts store sells "shims" and all it is is a "cap"! i know the terminals (on truck) are old, and have prob been clamped to tight to many times, i am returning to sears this week just to see if it is a bat prob, and more than likely i will be replace cable ends.
thanks for the input guys
WatsonR
02-17-2016 09:01 PM
fightlivefree
23
01-26-2016 05:30 PM
wakeupluis
01-13-2016 10:13 AM
busflyer
Electrical Systems/Wiring
08-16-2011 01:43 AM
a74ina72
05-17-2011 06:00 PM
Quick Reply: Diehard Gold Battery ?
