1955 F-100 TO 1952 Ford F-2 Frame Swap - Ford Truck Enthusiasts Forums
Old 02-06-2011, 08:07 PM
1954-5EFFIE 1954-5EFFIE is offline
1954-5EFFIE is starting off with a positive reputation.
Question 1955 F-100 TO 1952 Ford F-2 Frame Swap
Hello,
I have a 1955 F-100 and need to swap out the frame. How similar are the frames between the '55 F-100 and a 1952 F-2? Are the overall specs. the same, what would be involved to make it work?
Thanks for any help and information you can help us with.
Old 02-06-2011, 08:11 PM
havi's Avatar
havi havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
Not much resemblance at all. The F2 is longer, narrower in the front, has no clip/cab mounts in the same location, etc.... It would be a step backward, IMO, to try and make an even older frame work for a '55 f100. I would suggest either a newer frame, or graft a newer IFS, and/or IRS suspension to the existing frame.
Welcome to FTE.
Old 02-06-2011, 08:14 PM
Havi,
Thanks for the rapid response. I was afraid of that. Do you know what frames line up best; is it the usual 1953-1955 comparable?
Old 02-06-2011, 08:19 PM
havi's Avatar
Not really, the '55 frame is 34" wide from front to back which is the same for several years (up through '79 for certain models) that can be made to fit. There are several article in FTE that can help. Start here: Front Suspension Alternatives for 1948 - 1960 Ford Trucks, Part One .: Articles Just keep clicking on each article part to get a vast array of options. The end result is basically up to you and what your intent for your F100 is. Slammed street rod, air bags, stock but modern, etc... whatever floats yer boat.
1955 ford F600(?) for sale 1952henry 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 01-13-2017 03:41 PM
1955 f100 build twalters 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 12-11-2015 07:54 PM
1955 f100 project duanes55 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 03-02-2015 06:26 PM
1955 5.4 svt swap 1955 fordman 1948 - 1956 F1, F100 & Larger F-Series Trucks 22 03-27-2014 09:23 AM
1955- 1956 frame 1956in1956 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 12-18-2013 01:19 PM
Tags
1952, 1955, 1960s, f1, f100, f150, f2, ford, frame, frames, gear, running, swap, truck, wide
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
