Headlight switch wiring - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-06-2011, 02:38 PM
wrdabney wrdabney is offline
wrdabney is starting off with a positive reputation.
My aftermarket bumper deleted my fog lights and I added some spotlights on the bumper. I just wired the spotlights to the fog light wiring. My switch is now messed up and I just want to wire the spotlights to a seperate switch. Does anybody know what wires control the fog lights on the back of the headlight switch? Will I have to wire in a new hot wire to the new switch or does the headlight switch have separate hots for the headlights and foglights?
Old 02-06-2011, 02:58 PM
brd7666's Avatar
brd7666 brd7666 is offline
brd7666 has a very good reputation on FTE.brd7666 has a very good reputation on FTE.brd7666 has a very good reputation on FTE.
If you are installing aftermarket fog lights, you should wire them up from start to finish without using your existing wiring. You may run into other problems by using the existing wiring. For one thing, the fuse for your factory fog lights might not be big enough for aftermarket fog lights. I have heard of people wiring aftermarket fog lights to the factory fog light wiring, and have problems. I would start from scratch, and wire them from start to finish. Good luck.
Old 02-06-2011, 03:00 PM
I've had them on for about a year and haven't had a problem yet. I understand your concerns but it hasnt been an issue yet.
Old 02-06-2011, 03:08 PM
brd7666's Avatar
Quote:
What caused the switch to go bad? Switches are designed to handle certain amounts of power, so some switches can handle more power then others. If you are pulling too much power through the switch, it might work for a while, but then it's going to stop working.
Old 02-06-2011, 03:26 PM
I hate to admit it but what happened to it is kind of humorous. The switch broke off of where it's mounted. In other words it could still turn the headlights on but if I pulled it out to turn the spotlights on it would just pull off. I put some gorilla glue on it to try to get it to work again and I guess I put too much on it. Now I can still turn the headlights on but the switch won't pull out at all. I know, stupid mistake. But this is the reason for wanting to wire to a seperate switch.
Old 02-06-2011, 04:49 PM
TexasRebel's Avatar
TexasRebel TexasRebel is offline
TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.
why not get a new switch?
Old 02-06-2011, 05:10 PM
Because the cheapest ones I could find on eBay were like 100 bucks. I already have other switches so it would be better to just wire it to a new one I think.
Old 02-06-2011, 05:15 PM
shorebird's Avatar
shorebird shorebird is offline
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
A visit to a parts yard might fix you up.
Old 02-06-2011, 05:50 PM
TexasRebel's Avatar
www.partsguyed.com
w/auto, w/fog, headlamp switch for a 2008 F250 = $30.25 new...
not sure what year you have, but I'd be surprised if there is a $70 difference between any of the years
Old 02-06-2011, 06:18 PM
2001-2004 Ford F250 Super Duty Headlight Switch - Body Electrical - Motorcraft 01-04 F250 Super Duty Headlight Switch - 5339-05048611 - PartsGeek
This is the switch I have. My point is, whether its 30 bucks or 100, I already have other switches I can use and take 10 minutes of work so why not just wire up a new one and not have to buy a new ford headlamp switch.
Old 02-06-2011, 07:59 PM
cliles55's Avatar
cliles55 cliles55 is offline
cliles55 is starting off with a positive reputation.
On my '08, the headlight switch fog light wire was gray/violet.
Old 02-06-2011, 08:06 PM
LaredoF350's Avatar
LaredoF350 LaredoF350 is offline
LaredoF350 has a good reputation on FTE.LaredoF350 has a good reputation on FTE.LaredoF350 has a good reputation on FTE.
Quote:
Did you do any mods to your wiring? On my 2003 F350 I did the mod to have the fogs on with the high beams. I liked that, and am trying to figure out if that can be done on the 08 trucks. Or, should I just power the fogs with an upfitter switch?
Old 02-06-2011, 08:45 PM
TexasRebel's Avatar
it depends on how much you want to cut up the wiring. A replacement OE switch insures that you won't create electrical gremlins. Splicing a switch in as a fix opens up issues like back-feeding and shorting.
I've always been an advocate of repairing the problem instead of fixing it.
also, do you have an 01, or an 02-04? They are different... I wouldn't trust that link you provided.
http://www.trademotion.com/partlocat...layCatalogid=0
Old 02-06-2011, 10:23 PM
I have an '01. The link was just an example. I wouldn't necessarily buy from there.
Old 02-07-2011, 02:08 AM
TexasRebel's Avatar
www.partsguyed.com
99-01: the original Super Duty design... Not sure why, but that is one expensive switch that doesn't make a distinction between w/fog and w/o fog.
Fog Light ??? Bryan-G 1999 to 2016 Super Duty 2 04-02-2016 05:05 AM
08-10 XL Oem Fog Light Install Issue F.X.5 1999 to 2016 Super Duty 3 11-30-2015 05:06 PM
Fog light question kschroeder.DVM Excursion - King of SUVs 7 06-22-2014 11:57 PM
fog light switch Paul Moody 1999 - 2003 7.3L Power Stroke Diesel 26 01-17-2013 08:16 PM
Spotlight on Dent Nick_Good 1973 - 1979 F-100 & Larger F-Series Trucks 6 07-24-2011 06:31 PM
Tags
1999, 2001, driving, duty, f250, f350, fog, ford, headlamp, headlight, light, lights, super, switch, trucks, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
