351W front oil seal
Old 03-10-2003, 06:44 PM
bandit779's Avatar
bandit779
bandit779 is offline
351W front oil seal
I have an 1987 351W that needs a front main seal. I had a few qeustions if anyone has done this before.
Can the seal itself be removed/installed without special tools? Also can the balancer be reinstalled by pressing it on with the crankshaft bolt? I was also wondering if the balancer itself could be the cause of the leak. I would appreciate any help. Thanks in advance,
Erik
Old 03-10-2003, 08:24 PM
Mike W's Avatar
Mike W
Mike W is offline
351W front oil seal
Sometimes the balancer has a grove worn in it by the seal. There is a seal saver that goes over the shaft to fix this. You can reinstall the balancer with just the crank bolt. I have used a socket to replace the seal. You will need a puller to remove the balancer. I use a simple one that uses two of the pulley holes to attach to the balancer. I find that a longer then normal crank bolt is useful in removing it.
shuffster
29
06-22-2016 07:47 AM
mawagian
10-18-2015 04:41 PM
robjs111
09-22-2012 08:49 PM
z1121jack
09-23-2009 08:27 PM
serian
05-19-2002 02:08 AM
Quick Reply: 351W front oil seal
