How to adjust the "choke pulloff" on Holley - Ford Truck Enthusiasts Forums
Old 02-06-2011, 12:27 PM
cnice_37 cnice_37 is offline
cnice_37 is starting off with a positive reputation.
My '86 F250/ 351W has a Holley 4160. Its not a daily driver, so every time I take her out after sitting, the truck will start after a couple pumps of the pedal, stall, start again, stall again, etc. In the winter it takes usually 4 iterations, in the summer 2 to 3.
I've adjusted the choke itself and the same problem persists. I asked this question before, and it led me to adjusting the choke pulloff, rather than just the choke housing. Electric choke btw.
According to this publication : http://holley.com/data/Products/Technical/199R8339.pdf I need to adjust the tang. However, what am I adjusting to? The instructions are fuzzy to me at best. Paper clip & voodoo.
Also, is there a quicker way to verify this is indeed my problem (thinking like limiting the choke pulloff with finger or coathanger if one man operation)? When the truck stalls, its about 3-5secs into firing, so an overly rich condition should only be present on that order of time. By my eye, when the choke does pulloff, it's probably wider than 1/4" but less than 1/2" - is that about right?
Thanks as always guys. One day I'll get it right.
Old 02-06-2011, 01:34 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Over 1/4" sounds wide to me, but there should be a chart somewhere that tells you what it should be for your specific model. Since you mentioned the paper clip, I am going to assume you have the integral choke model.
It should be simple enough to test the operation. All you are doing with the paper clip is manually actuating the choke pull-off system by moving the piston. The piston normally works on vacuum. If you get the piston moving with the paper clip, then you can see how the whole system works by moving it back and forth, and it will become clear what to bend.
Old 03-10-2011, 08:45 PM
eriklane eriklane is offline
eriklane is starting off with a positive reputation.
choke pull-off
Any idea where I can get a new choke pull-off? The nut that adjusts it was so rusted that I cannot hardly turn it, and, at 5-10 bucks, I'd gladly pay for a new one...Napa and AutoZone don't have em.
Dang thing is also so close to the fuel inlet, I cannot tighten the larger nut there because of no room and hitting the pull off...wanting to take the pull-off out...
Old 03-10-2011, 09:03 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
My first thought is a local speed shop in your area....
From Let me google that for you
Places for speed shops near Rockford, MI
Nelson's Speed Shop
- 2 reviews - Place page
<cite>Nelsons Speed Shop, Arctic Cat, Yamaha, Polaris, Parts Unlimited, Honda Power, Stihl, Greenville, MI</cite> - 4566 South Greenville Road, Greenville - <nobr>(616) 754-9185</nobr>
Speed Merchants
<cite>maps.google.com</cite> - 106 E Bridge St, Rockford -<nobr>(616) 866-2226
</nobr>
Next would be Holley's Web site:
Holley Performance Choke Service Parts Products
Old 03-10-2011, 11:30 PM
choke stuff
Thanks, I may end up yanking this carb and getting an up close look at it all.
Autolite 2100 - Fast Idle yabadaba 1967 - 1972 F-100 & Larger F-Series Trucks 8 05-15-2016 11:29 AM
truck problems in mornings driftingrz 1967 - 1972 F-100 & Larger F-Series Trucks 8 09-29-2014 02:44 PM
Choke questions answered. fmc400 1973 - 1979 F-100 & Larger F-Series Trucks 55 07-30-2014 11:11 AM
No choke pull-off clearance? mktsc 1973 - 1979 F-100 & Larger F-Series Trucks 3 10-13-2011 07:21 AM
Motorcraft 2150 giving me troubles Jermafenser Fuel Injection, Carburetion & Fuel System 17 02-18-2009 01:35 AM
Tags
1989, 351, 4160, 86, adjust, adjusting, adjustment, choke, electric, f100, f150, ford, holley, pull, truck, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
