1997 F-350 for parts. 5 speed trans case axles, cab and more.
Category: Drivetrain
Price: $1
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): Fit, S2000, CL, TL & Vigor, Hybrids
Item Condition: TN
Engine: Part suitable for gas truck, Part suitable for diesel truck
Chadder You should be able to PM. You may have to go to "User CP" to turn it on.
I will send you a message.
You should know there is not much left. The tranny and trans case are considered sold, sale pending. Steering column is gone, sold.
The body was pretty rusted so the bed is on my trailer with all of the body panels in it waiting to go to the scrap yard. The tranny and Trans case are removed and taken apart. The steering column is sold.
About all that is left is the cab shell with dash, frame, fuel tanks (one bad) and axles.
Are you still interested?
I never heard back from you Chadder.
I assume you are not interested.
Anybody else interested in the D-60 or rear axle or any of the interior parts?
I have pics I will try to put up tonight.
ZF still available?
Concerning ZF, you indicated good case. Is gear train loose or noisy or were you just commenting that case hadn't been damaged.
What Engine? looking for ZF to bolt up to 300/ford small block bolt pattern.
This had a 460 in it. Tranny has sale pending. You interested?
#29
Yes it has dual tanks but the rear tank has holes in it. The front tank is fairly new but surface rust on it. You can have the bed for free but I honestly don't think you want it.
Oh, I also removed the fuel door buckets from it. See pics above.
It depends on how much you want.
-Axle only (with knuckles and brakes) -$700
-Axle with all steering components -$800
-Axle with all steering components and springs and brackets -$1000
-Axle with all steering components and springs and brackets and double cardon front driveshaft with the F-350 Transfer Case Yolk -$1200
This axle has had balljoints recently replaced so it is ready to drop in and go!
