7.3 code po603 internal ctrl mod KAM ERROR - Ford Truck Enthusiasts Forums
General Diesel Discussion SPONSORED BY:
Old 02-06-2011, 11:27 AM
sodbuster608 sodbuster608 is offline
sodbuster608 is starting off with a positive reputation.
WHAT DOES THIS MEAN AND HOW TO FIX RUNS ROUGH AND MISSES
Old 02-06-2011, 03:13 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
http://www.ford-trucks.com/forums/10...ont-start.html Have a read through this link for ideas. In particular if you have a chip or maybe try cleaning the connector to the PCM.
For more info maybe try posting the problem on the page for your engine.
Good luck.
Old 02-06-2011, 08:48 PM
thanks link very helpful
Old 02-06-2011, 09:39 PM
found problem chip was dusty and alittle loose fixed all problems thanks again
Old 02-07-2011, 06:12 AM
Good man. Glad you got it fixed.
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
Can someone explain this to me? 1987 - 1996 F150 & Larger F-Series Trucks 11 03-09-2016 01:40 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
DPSE Roachfood 1987 - 1996 F150 & Larger F-Series Trucks 3 03-11-2002 11:21 PM
Tags
01, 250, 73, code, ctrl, diesel, dtc, eng, error, ford, internal, kam, mod, performance, po603, po603pcm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
