another front end alignment question '97 f250 FWD - Ford Truck Enthusiasts Forums
Old 02-06-2011, 07:43 AM
mnk mnk is offline
mnk is starting off with a positive reputation.
Question another front end alignment question '97 f250 FWD
i'm replacing front tires on my 1997 f250 heavy duty FWD. they're showing wear on the inside of the tire so i want to have the alignment done as well (hasn't been done since i got the truck few years ago). truck has stock suspension. took it to a local shop to get a price on the alignment. the price is $90 but then the mechanic said if offset cams are needed then it's $150 a piece.
i tried googling offset cams, alignment cams, camber bolts, etc, but i'm not getting any answers. i did see that camber bolts run about $50. so now i'm a bit confused by the quote i was given.
can someone explain this to me? i want to be a little more educated when i head back to the shop. what's the deal with these camber alignment bolts?
thanks in advance!
Old 02-06-2011, 08:25 AM
jrwhitmire jrwhitmire is offline
jrwhitmire is starting off with a positive reputation.
He's talking about offset camber bushings, they go below the castle nut of your upper ball joints, from spring wear your tires probably look like this viewed from the front, / \, unless it's lifted, then it's probably like this \ /.
Old 02-06-2011, 03:24 PM
StumpPullerF1 StumpPullerF1 is offline
StumpPullerF1 is starting off with a positive reputation.
Normally they wont need to change them unless youve done something pretty major to the front end, lift, lower, etc.
Old 02-08-2011, 01:22 PM
mnk mnk is offline
thanks!
no changes to the suspension. it's stock. new shocks and springs were replaced a while back when i first bought it.
i'm taking it to a shop someone on this board recommended (the front end shop in nj). i may pay a premium but sounds like i'll at least get quality service. i know what work has been done to the truck so hopefully they won't try to recommend replacement of parts not needed...
Camber specs for 2001 F250 2WD - Questions after lift kit install and alignment... John7894 1999 - 2003 7.3L Power Stroke Diesel 9 02-13-2017 09:00 AM
03 Expedition alignment ScottyDsntKnow 1997-2006 Expedition & Navigator 7 01-17-2015 12:17 AM
2000 Expedition Front End Alignment flcracker9 1997-2006 Expedition & Navigator 5 12-13-2012 10:11 PM
TTB alignment jimjoebob99 1987 - 1996 F150 & Larger F-Series Trucks 13 10-26-2010 09:38 AM
Ford Truck alignment procedure and tips cantedvalveFord 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 0 02-19-2009 01:35 PM
Tags
1997, 97, aliginment, alignment, cost, duty, end, f150, f250, f350, ford, front, hd, heavy, island, rhode
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
