electrical queerness
experienced this short time ago: driving on motorway @65mph, set turn signal to the right because shifting the lane and the overdrive kicked out and in with the same frequency as the turn signal got on and off. anyone an idea what can cause this? wiring seems to be fine in the truck, no other problems in the electrical system so far.
Check your trailer connector and the brake light bulbs. I'd pull all the connections apart and blow them out then reattach. Also look for any wire back there that could have rubbed through and is grounding.
I haven't heard of this one before but it's common for the brake lights to shut off the cruise control when one burns out.
Hey I have been wondering how you drive that thing out there? Don't all the cars try to run you off the road? And look out because our Danish girl is getting her license now.
Hi Michael, Good to see you!
I am trying to picture what is happening. Is your steering wheel turned a little?
My wheel is turned a little (when I am going straight) and when I put my turn signal on I need to hold it there until I actually start turning....then it will hold. Then it will cancel like it should (when I am turning the wheel straight again).
thank you all for the input
