48/60 Forum Tips, Tricks, How To's! - Page 2 - Ford Truck Enthusiasts Forums
Old 10-16-2012, 12:48 AM
edsf100's Avatar
edsf100 edsf100 is offline
edsf100 has a very good reputation on FTE.edsf100 has a very good reputation on FTE.edsf100 has a very good reputation on FTE.edsf100 has a very good reputation on FTE.
When I made plans to build my 1956 Ford F-100 I immediately knew that I wanted to have it roll on a combination of 18-inch front wheels and 20-inch billet wheels for the rear. I wasn’t targeting the pro-street look, but wanted a minimum of a 20 x 10 inch rim for the rear, which a couple of buddies told me was impossible to do on an F-100. (Read More)
Old 10-16-2012, 10:36 AM
vntgtrk's Avatar
vntgtrk vntgtrk is offline
vntgtrk is starting off with a positive reputation.
Quote:
Definitely cool. Too bad I'm one of the budget conscious (poor) truck builders here
Old 11-14-2012, 10:10 AM
Tbuilder Tbuilder is offline
Tbuilder is starting off with a positive reputation.
Original Paint
Can you help me find a thread somewhere that helps me with the orginal paint schemes for detail parts? I have done the research to understand the standard exterior colors, the yellow for the engine on my 56, etc. Now I am down into the finer details, for example: 1) are the inner fenders black or body colors, 2) what color should all of the clutch and brake linkages be painted, 3) what color should brakelines be painted or not at all, what about all of the clips for different things - black or body color, etc.
I just can't find these details enywhere.
Thanks for all of your help. Great site!
Old 04-07-2013, 08:33 PM
Bunny Blue 52's Avatar
Bunny Blue 52 Bunny Blue 52 is offline
Bunny Blue 52 is starting off with a positive reputation.
Info for newbies
Thanks for the sites...
Old 11-29-2014, 10:25 PM
Mcmannisjr Mcmannisjr is offline
Mcmannisjr is starting off with a positive reputation.
Looking for pics on using mid 60 s mustang tank in rear frame rails of 48-50 f 100 have 49 ready to make clean swap even if I gotta do some frame mods. Thanks
Old 11-29-2014, 11:36 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Welcome to the forum, McMannis! You need to do an Advanced Search to find specific info like that. NOT the big Search box at the middle/top of the page, click on the smaller Search in the blue bar and it will drop down a dialog box with the option to do an Advanced Search. Put in the topic you want to search for, and limit the search to this forum (see below.
Old 03-20-2015, 11:48 AM
petemcl's Avatar
petemcl petemcl is offline
Still Learnin'
petemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to behold
Emergency brake (park brake) system - F2
While trying to piece my ebrake system back together (yes, I forgot to take pictures before disassembly) I used pictures from many different posts from many of you posted over quite a few years to get the answers that I needed for the entire system. My thanks to all of you who have posted. I couldn't have done this without you.
This post is an attempt to put it all together into one post. I hope that it helps not only those of you restoring F2s but F1s, F3s, etc. as I believe that most use variations of this same basic design.
Many of these parts are very hard to find.
Ford cars 1939-1948 use the same parts under a different number.
Ford Car cross reference - same parts as 1948-1951 Ford F2 Truck
Old 10-28-2015, 01:30 AM
underthebridgejim's Avatar
underthebridgejim underthebridgejim is offline
FTE fan
underthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputation
Help installing cab support arms with new rubber snubber in place. http://www.ford-trucks.com/forums/14...l#post15738116
Old 11-03-2015, 01:18 PM
petemcl's Avatar
Still Learnin'
Correction
Ross pointed out that I need to find a shouldered bolt to allow automatic equalization:
Thanks for spotting that Ross.
Old 11-26-2015, 09:44 PM
chad77's Avatar
chad77 chad77 is online now
chad77 is gaining momentum as a positive member of FTE.chad77 is gaining momentum as a positive member of FTE.
countersink trick - sheet metal
So I bought an altmans easy latch kit for my 56'. They have done a good job with the latch for sure. But its not clean enough for MY liking.
I didn't want to cap my door with another piece of sheet metal, that they supply, to hold the latch in place.
I plan on filling the factory holes and cutting my own holes etc in it afterwords.
I wanted to counter sink the bolts in my door like they came with the easy latch/plate. Tried searching for a punch or die locally, but no luck.
So I made one. Cost me nothing to make really. I have attached a picture. It's just a countersunk bolt with a big nut, a washer, and a nut that threads onto the bolt. The nut, washer, and big nut are welded together to keep the bolt centered in the hole when tightened.
Took a couple trial runs before I got an even punch, but it works great!
Old 02-22-2016, 04:09 PM
Col Flashman's Avatar
Col Flashman Col Flashman is offline
Col Flashman has a very good reputation on FTE.Col Flashman has a very good reputation on FTE.Col Flashman has a very good reputation on FTE.
There was an Articles here on F.T.E. that showed how to Upgrade ones brakes to a Mid-Late '60s Mustang Dual Master Brake Cylinder & w/ the change that happened at the F.T.E. site I can no longer find it. Also, I saved it to my Gallery using a Screen Shot & my Gallery no longer exists. Any way to retrieve thatas well would be greatly appreciated.
There was also an Article about doing the Up Grade using an Early '70s F-150 Master Brake Cylinder as well, which I also can no longer find.
These are all for my '58 Mercury M-100 truck.
Please I could really use someones help here in locating these articles, thank'ee.
Old 02-22-2016, 06:35 PM
56panelford's Avatar
56panelford 56panelford is offline
Posting Legend
56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation
Ford Truck Enthusiasts User Gallery
Here is the link to your galleries, real good to see you back on here..
  #28
Old 02-22-2016, 08:16 PM
Thank'ee kindly & I hope this finds you Hale & Hearty.
19 months of sleeping in my wife, Nancy's, Hospital & Facility rooms since she was diagnosed w/ A.L.S. on 4 Aug., 2014 & became immobile 1 Oct., 2014.
Barely hanging on by our finger nails financially as well & very close to losing everything.
  #29
Old 05-16-2016, 07:33 AM
topmoo's Avatar
topmoo topmoo is offline
topmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant future
So sorry to hear that, ALS is such a terrible and non curable condition. One of my best friends, a Doctor (a pediatrician), was just diagnosed with ALS. He is having to quit his practice and prepare for the worst. A very sad situation for anyone, and for the loved ones around them. Bless you and your wife.
  #30
Old 05-18-2016, 09:43 PM
52 USCG Panel's Avatar
52 USCG Panel 52 USCG Panel is offline
52 USCG Panel has a good reputation on FTE.52 USCG Panel has a good reputation on FTE.52 USCG Panel has a good reputation on FTE.
Col Flashman, I too wish to express my sincerest sympathy to you and your wife. We believe that our lives are in God's hands and we often times take His blessings and positive outcomes for granted, but because of evil in our fallen world, bad things can and do happen to good people. In life's darkest moments, we can, however, take comfort in knowing that God is ultimately in control. Our life here in this world is always very brief and may at times be filled with great pain and sorrow. In every trying circumstance, we can be absolutely certain that because of God's grace, heaven is our real home and the trials of our temporal lives will be completely forgotten. May God grant you peace and strength as you face these difficult days.
GM Swap Completed, can I go back? GSEninja 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 04-01-2014 05:46 PM
Frequently Asked Questions link Maltman 1957 - 1960 F100 & Larger F-Series Trucks 0 02-15-2014 02:17 PM
2011 excursion. WHAT!!! its on ford enthusiasts forum Rosson03 Excursion - King of SUVs 35 01-18-2012 06:31 PM
Read first- FAQ and MANY more 1948-1960 Ford truck related articles Fomoko1 1948 - 1956 F1, F100 & Larger F-Series Trucks 40 10-25-2010 12:28 PM
Replacing a window BigF350 1967 - 1972 F-100 & Larger F-Series Trucks 2 06-27-2009 06:51 PM
Tags
48, 4860, 57, 60, cylinder, enthusiasts, f150, f350, ford, fordtrucks, forum, lightning, lubrication, parts, tricks, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
