How to undull inside of headlights?
Well i figured i would buy some new headlights along with a set of H.I.Ds sense the kit is only around $80 bucks or so then throw a pair of KC 6"x8" fog lights on the brush guard but intell then i wanted to see if there was something to fix the problem because when it rains i might as well not have my headlights even on...
Over all, after getting the HID lights, I will never use anything else, and I want to convert the driving lights now.
I vote for getting new headlight assemblies either stock or crystal clear, but not euro crap, a relay setup, and some good clear bulbs like GE Nighthawk or Sylvania Xtravision. Please do not do the HID retrofit, its illegal and produces excessive glare to oncomming drivers. None of the available headlamp assemblies are designed for HID, they are designed for Halogen.
Thanks .... So I am not the only one that wants to build a laser and tracking system to destroy those non DOT home install lights that the traffic patrol will not enforce laws against! Especially the ones that do not aim the light slightly to the right of the car so as not to blind oncoming drivers.
The reason i want to do the H.I.Ds is because of the dramitic light out-put vs stock or just replacing with halogen bulbs. I also do alot of driving on backroads sense i live about 8 miles out of the city which is another reason i would like the higher light out-put HIDs my buddy had a pair on his 2006 dodge ram and they did not by all means blind other drives sense he had them aimed the way they should. I do agree with you do not aim them they way they should they can blind other drivers but if done right they wont anymore then a high ouput halogen bulb. My only reason i am not sure about the HIDs is like stated above about these headlights not being made for them so i dont want to buy a new pair and have the bulbs burn the cases. For now i figured i will buy a pair of Sylvania Silverstar Ultras which are like $50 bucks and when i install the push bar with brush guards and 6"x8" KC halogen fog lights i think i could do without the HID's. Like i said before i was wondering if i could just open the headlight assemblies up to clean the actual lenses intell i buy the new ones. I am placing a order all at once for everything sense it is a huge list and making sure i am still in budget but i may just buy the headlight assemblies ahead of time sense lighting up the road is a issue.
It doesn't matter the reason. Aiming them down helps a little but its not enough. The optics of the headlight assembly is incorrect for HID. Its a bad idea because its affects on comming drivers.
Something else to consider is that not everyone's eyes are the same and what bothers someone else may not bother you.
Just get some good Hella or KC driving lights.
Don't waste your cash on Silverstar bulbs. They are tinted and just appear whiter and really aren't brighter. Stay with clear bulbs. GE Nighthawk Platinum is something new, but I have no experience with them. They also have a blue ring on them, and I'm not sure what that is supposed to do.
These GE Nighthawk are my favorite, with Xtravision just behind them. They are less than 30 bucks. Don't get sport series they are tinted too.
Amazon.com: GE 9007NH/BP2 Nighthawk Automotive Replacement Bulbs - Pack of 2: Automotive
Exactly what he said. Those lights are not designed to have that light patten in them so it just scatters the light all over the place and you blind on coming divers
#28
The bulb's focal length and the lens's diffraction pattern don't really work with an HID retrofit kit at all.
I replaced both my headlamp assemblies and added a relay kit from LMC a couple of years ago.
The more direct power supply and added grounds made a world of difference.
Read more than you ever wanted to know from one of the best in the industry: Daniel Stern Lighting Consultancy and Supply
#29
the only way i know of to clean the inside is to take the lens off and polish it. it does work just time consuming cause you have to unglue it clean it and then reglue it. or you can get new ones. Also can yall stop badgering him and everyone else about the damn HID's ok fine tell them once twice ok send a link or two but i hate seeing a good thread ruined! Now im hoping that someone else can chime in with more USEFUL information on the subject at hand about the cleaning of the insides of the lens'.
#30
There are a few products out on the market to clean the lens. 3M makes a product, Turtle Wax, Meguiar's as well.
Personally, I plan on just replacing mine. The time invested in cracking the seal, then the time cleaning the lens, then the time putting it back together is time that could be spent on another project.
Here are step by step instructions to clean the lens:
How to Repair Oxidized Cloudy Headlights with a Headlight Cleaner - wikiHow
