E Van Wheel Lug Diameter? - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 02-05-2011, 10:18 PM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Contemplating four aluminum wheels for my 2000 E250 and curious what bolt circle and back spacing would be considered stock? I do know my current steel wheels are 16 diameter x 7 width--no idea what the lug circle is though.
Won't be running anything bigger than an LT245 or LT265.
Old 02-06-2011, 12:19 PM
Grems4ever's Avatar
Grems4ever Grems4ever is offline
Grems4ever has a very good reputation on FTE.Grems4ever has a very good reputation on FTE.Grems4ever has a very good reputation on FTE.
The bolt circle is 8-165. This is different from the F-Series truck's 8-170 so don't be lured into a great deal on a set of truck wheels because they will not fit.
As for backspacing, I don't know what the factory specs are, but many of the aftermarket wheels for the E-Series tend to be in the 4 - 4 1/4" neighborhood. To determine the stock backspacing, hold a straight edge across the rim and measure back to the mounting flange. I'd measure my spare for you, but I don't feel like rolling around in the snow/ice to figure it out.
Old 09-19-2013, 07:42 PM
cherokeexj32 cherokeexj32 is offline
cherokeexj32 is starting off with a positive reputation.
backspace
Were you ever able to determine the amount of backspace the rims had?
Old 09-19-2013, 08:16 PM
Grems4ever's Avatar
Sorry, but I forgot totally about it.
3/4Ton 8 bolt wheel interchangability acoss the years? James_Western_Canada 1961 - 1966 F-100 & Larger F-Series Trucks 7 07-17-2016 11:01 AM
Lug Nuts and Studs!!!!!!!! bignewf 1973 - 1979 F-100 & Larger F-Series Trucks 4 04-21-2016 06:24 PM
F250 Lug Nuts and STUDS.!!!!!!!!! bignewf 1987 - 1996 F150 & Larger F-Series Trucks 5 04-21-2016 01:31 PM
5x5.5 vs Metric Bolt Circle danlee Brakes, Steering, Suspension, Tires, & Wheels 0 03-03-2016 08:08 PM
Does a Dana 50 dog dish center cap exist? Tom in NH 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 09-14-2015 07:11 PM
Tags
08, 2000, backspacing, bolt, circle, diameter, eseries, f350, ford, lug, lugs, radius, size, van, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
