Painting interior trim pieces thread :) - Ford Truck Enthusiasts Forums
Old 02-05-2011, 10:18 PM
93f250tn's Avatar
93f250tn 93f250tn is offline
93f250tn is starting off with a positive reputation.
Well as you all may know i am doing a ton of things to the exterior/motor/drive train so i figured i will do some updating on the interior as well Its easy to do, cheap and can make a big difference. I will first be doing the actually trim pieces, awhile back one broke and had to replace it and i dont really like the stock coloring on them. I will be painting them metallic silver to match the metallic silver pin striping on the outside of the truck. Heres what i will be using...
- Rost-oleum Painters Touch Ultra Cover Primer
- Rost-oleum Painters Touch Ultra Cover Metallic aluminum
- 600 grit wet sand paper
- Acholol wipes
In order to pop off the trim pieces i used a knife, do NOT force them off or you will break the clips. Slightly pry upwards with the knife and work your way down the trim piece. The ones on the doors are metal so are more tricky well the plastic ones pop off really easy. I will also be doing the grills of the speakers, the plastic covering around the gauges and a few other little things after i finish this little project still not sure if i want to paint them silver or go with a gloss black. I will be adding pictures as i go
Old 02-06-2011, 12:26 AM
93f250tn's Avatar
Just finished wet sanding everything, then wiped everything down with acholol pads to get any of the dirt off to make the paint apply better without any little dirt specs in it. The black piece that has the XL on it was rough unlike the other ones that were smooth, i sanded it down so it is smooth like the rest with 600 grit. I should have done it with 320 grit then finished with 600 to smooth it out but alittle extra elbow grease never hurts anything... Be very careful with the 2 metal trim pieces they bend very easily and are a pain to bend back. When you wet sand the smooth pieces you dont need to apply much pressure because you the surface is already smooth you just need to get that clear coating on it off. After the second coat of primer i will post up pictures.
Old 02-06-2011, 02:33 AM
93f250tn's Avatar
Some pictures after 2 coats of primer...
now for two coats of the metallic silver
Old 02-06-2011, 03:05 AM
rockin300's Avatar
rockin300 rockin300 is offline
rockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud of
lookin good heres mine
Old 02-06-2011, 03:31 AM
93f250tn's Avatar
Quote:
I like the headliner! i was thinking about doing something like that with some mossy oak camo sense i will be getting mossy oak seat covers and bench seat cover :0 I am still debating on weather to paint the speaker grill covers, gauge cover, and a few other things this metallic silver or gloss black i guess when i put these in the truck this morning ill see how it looks and go from there
Old 02-06-2011, 03:37 AM
rockin300's Avatar
yep thats what i did to and it went from there
Old 02-06-2011, 03:43 AM
93f250tn's Avatar
do you have any more pictures of your interior? it has given me some ideas
Old 02-06-2011, 03:46 AM
rockin300's Avatar
no not right now but i know im doin the seats next and the guage cover
Old 02-06-2011, 06:40 AM
93f250tn's Avatar
This is 2 coats of primer and 2 coats of paint later one piece is still drying which is why it is not in this picture but i think i will end up painting them gloss black along with everything else (gauge cover, plastic by power windows, vents, and a few other things i am probably forgetting) It came out well, and if you plan on doing this even though it says it will dry in 30 mins give it a good hour in between coats just to make sure. I will have to pick up some gloss black later today and will post up pictures either tonight or Monday.
Old 02-06-2011, 07:57 AM
SouthernBlues's Avatar
SouthernBlues SouthernBlues is offline
SouthernBlues has a good reputation on FTE.SouthernBlues has a good reputation on FTE.SouthernBlues has a good reputation on FTE.
Quote:
I have the same headliner in my truck
Old 02-06-2011, 10:27 AM
HrdDrv's Avatar
HrdDrv HrdDrv is offline
HrdDrv is gaining momentum as a positive member of FTE.HrdDrv is gaining momentum as a positive member of FTE.
Before,
After,
Also did the roof trim to break up the red...
Old 02-06-2011, 10:51 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
How do you plan on putting the trim back on the door panels since you broke the clips that hold them on?
Old 02-06-2011, 12:33 PM
StumpPullerF1 StumpPullerF1 is offline
StumpPullerF1 is starting off with a positive reputation.
The trim looks nice. Where can you get the clips to hold them in? One of mine is missing.
Old 02-06-2011, 12:39 PM
jk89cat jk89cat is offline
jk89cat is starting off with a positive reputation.
Quote:
my thoughts exactly!
Old 02-07-2011, 01:19 AM
93f250tn's Avatar
I didnt break any clips lol i said if you pull them out they are very fragile and will break easy... If you do happen to break the clips, double sided tape is your best friend. 2 clips are broken on my gauge cover and did this and works great. I went and bought a few cans of gloss black and will be painting everything tonight and go from there... I have a ton of red in my truck so still deciding on what i want to keep red or switch to black.
Chrome plastic trim touch up? TheSterling 1973 - 1979 F-100 & Larger F-Series Trucks 1 04-01-2016 07:02 AM
33" tires fit on stock f150 4x4 93f250tn 1987 - 1996 F150 & Larger F-Series Trucks 27 03-27-2016 11:45 AM
New to me 97 F250HD 4x4 7.3 Powerstroke 93f250tn 1987 - 1996 F150 & Larger F-Series Trucks 5 03-07-2013 06:18 PM
Need brake line advice! 95 f150! 93f250tn 1987 - 1996 F150 & Larger F-Series Trucks 5 10-19-2010 03:50 PM
95 F150 351W True dual exhaust pics+video 93f250tn 1987 - 1996 F150 & Larger F-Series Trucks 4 09-14-2010 05:14 AM
Tags
1994, 350, 99, camo, cover, exterior, f150, ford, interior, mossy, oak, paint, pieces, trim, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
