1997 f350 starter relay wiring diagram - Ford Truck Enthusiasts Forums
Old 02-05-2011, 07:21 PM
mstolz60 mstolz60 is offline
mstolz60 is starting off with a positive reputation.
Not sure this is the right forum but I don't see one for a 1997 F350. My son went to replace the relay and didn't pay attention when he took the wires off So I need something that shows me what goes where.
This is the relay that is on the passenger side fender well.
Thanks for the help!
Old 02-05-2011, 08:14 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
You have one Red wire on one of the large studs that goes to the starter.
One small red wire with a blue stripe the that goes to the coil of the relay.
All the rest go on the other large stud with the wire from the battery.
Old 02-06-2011, 11:40 AM
Hey Bill,
Thanks for the quick reply. I'm stupid when it comes to wiring so I have one more question. For the red wire with the blue strip, how do I know which small termal (relay coil) it goes to? Does it matter? Do both small terminals go to the relay coil?
Mike
Old 02-06-2011, 12:17 PM
subford's Avatar
There should only be one small terminal on top.
Old 02-06-2011, 12:31 PM
subford's Avatar
Diagram:
Old 02-06-2011, 03:45 PM
Thanks Bill, You da man!
Mike
Old 02-15-2011, 12:26 PM
Solenoid stays engaged - Original 1997 f350 starter relay wiring diagram Reply to Th
Bill,
Here is the history of this whole event. My son installed a new flex plate and starter (including solenoid) into his 7.3 F-350 because the plate teeth were gone when he bought it. After this all worked well until the screws on the starter solenoid came loose and messed it up. He installed a new starter solenoid and after doing so every time the key is turned the solenoid will stay engaged until we disconnect the battery.
Given he just installed a new solenoid and this issue started, he returned it thinking it was defective and installed a new one again. STILL THE SAME ISSUE.
As a result of reading the forums we have installed the switch in the steering column once and the relay on the firewall now for the 3<SUP>rd</SUP> time because it appears to stay hot across the terminals using a test light.
Whatís weird is after installing I think the fender well relay it worked for a few days but started again.
Last night we put in the third firewall relay with the exact same problem, hit the key and the solenoid stays engaged until the batter cable it pulled.
After replacing the relay so many times my son questioned if he had the wiring right which is why I started this thread. You of course provided us with great detail but now weíre stuck.
This sounds like a short or something but we have traced the wires and canít find a thing.
I always work on my own stuff and am reluctant to take it to a shop because of the costs but Iím baffled on this one.
Any ideas?
I do have one thing that I have been wondering about. When the screws came out of the starter solenoid they got stripped so we replaced them with some I got at the local Napa store, not like the original. The screws that were on the original have like a cone shaped rubber insulation under the head and Iím wondering if this has something to do with the shorting. This really doesnít make sense to me because any screw would still make contact with the starter, just something I noticed.
Thanks
Mike
Old 02-15-2011, 05:29 PM
subford's Avatar
I have heard of this before, the starter relays at the auto parts stores are sub standard and the only way to solve the problem is to go to a Ford dealer and buy a starter relay from them.
Old 11-23-2011, 11:14 PM
PurerockRacing's Avatar
PurerockRacing PurerockRacing is offline
PurerockRacing is starting off with a positive reputation.
Hello, I believe my starter relay went out tonight in front of my house, 2001 Ford V10 chassis motorhome. Battery and everything checks out good and now after installing a new starter, same problem. Starter does not move. So now I am thinking it's the relay. The photo in this thread shows it's riveted to the frame. I can hardly see mine behind some rubber shield on the side of the radiator mount (passenger). Are these easy to replace? It's dark outside now so I'm screwed at the moment till tomorrow (thanksgiving day)...
Old 11-24-2011, 12:45 AM
82F100SWB's Avatar
82F100SWB 82F100SWB is offline
82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.
On a psd, the fenderwell solenoid only sends voltage to the solenoid on the starter, not like the pre 92 gas trucks that didn't have a starter mounted solenoid. If changing the fender mounted solenoid didn't fix it, I'd lean towards the solenoid on the starter itself hanging up. the starter is fed with a cable directly from the battery, so if it's solenoid hangs, it will keep running.
Purerockracing: the solenoid is not riveted on, those are the rivets holding the base on the solenoid. It's a bolt on affair. However, I'm not sure about motorhome chassis, but trucks around your era were bad for the lead going to the starter corroding and rotting off. You may not have a solenoid or relay issue, but a bad wire somewhere.
Old 11-24-2011, 07:34 AM
subford's Avatar
Purerockracing:
You may have a bad fuse also if the starter relay does not click when you turn the key, check fuse number 7.
2001 F53 start circuit:
Old 06-14-2012, 02:16 PM
jwaggoner jwaggoner is offline
jwaggoner is starting off with a positive reputation.
Quote:
replaced my relay like shown here, all wires in the same location as they came off, hooked up the jumper cables because battery was dead and now the wire coming off the right side of the relay to the alternator caught on fire... key was in the off position. ????????????? any help?
1985 f150 fuel pump relay question captain1997 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 03-08-2016 09:11 PM
1997 F350 relay #2 under hood fuse box superdutyf450 1994.5 - 1997 7.3L Power Stroke Diesel 1 11-24-2014 10:32 PM
92 F350 Alternator Wiring Dasvigo WTB - Parts & other 0 05-24-2012 08:48 AM
1997 F350, cranks, but won't start, code P1670 blackdakotadave 1994.5 - 1997 7.3L Power Stroke Diesel 29 01-17-2012 08:16 PM
1997 F350 diesel wiring diagram RVSupply 1999 to 2016 Super Duty 6 12-18-2007 09:51 AM
Tags
1987, 1996, 1997, 75, 83, 97, coil, diagram, f350, ford, location, powerstroke, relay, starter, truck, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
