1995 f-150 engine swap
Old 02-05-2011, 03:27 PM
84f250mudder's Avatar
84f250mudder
84f250mudder is offline
hi everbody,
im looking to swap out the inline 6 thats in my 1995 f-150 to a 351w in the future. my only problem is that ive been looking around and i can only find brand new 351s that are carbed. am i able to re-use the efi thats on my motor? if i can someone please explain to to switch is from carbed to efi and if not please give me a website i could order a NEW 351w from.
thanks,
Bill
Old 02-05-2011, 04:17 PM
92nite351's Avatar
92nite351
92nite351 is offline
the efi is different you would need the set up off a 351 from a truck like ours. your best bet is to find a doner truck and take everything from it...
Old 02-05-2011, 07:29 PM
Edgethis's Avatar
Edgethis
Edgethis is offline
Well most of the difference b/t carb and efi is all in the intake manifold. Some others are the cam eccentric for mech fuel pump. Best bet is to either pull an entire setup out of a junkyard or check c-list and classifieds.
Old 02-05-2011, 11:03 PM
Gregallen's Avatar
Gregallen
Gregallen is offline
Go to a junkyard and get a motor or find a truck in bad shape. Thiers a lot of parts that u will need to do the swap. I am finishing up the same project.
Old 02-06-2011, 02:26 AM
93f250tn's Avatar
93f250tn
93f250tn is offline
you can get a remanufactored 351w EFI for $1600-$1800 bucks with 3 year 100k warranty from pro built.
Old 02-06-2011, 05:30 AM
Edgethis's Avatar
Edgethis
Edgethis is offline
That wont come with all the external parts he'll need, i.e. the air intake tube/box, sensors, usually don't come with fuel rail/injectors....
Oxfordrider
07-11-2014 11:11 AM
JAYSTR
02-23-2008 11:47 AM
martimani85F250
02-02-2006 07:25 PM
ATC_250SX
18
11-10-2004 04:27 PM
Volim
01-12-2003 10:47 AM
Quick Reply: 1995 f-150 engine swap
