no brake lights?? help - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-05-2011, 01:00 PM
piedpipper5 piedpipper5 is offline
piedpipper5 is starting off with a positive reputation.
I have an 04 F250 with no brake lights. However the third brake light works. Ive also noticed that my trailer brake lights dont work either. I do
have all my turn signals and running lights. Another issue that could be connected is I have one out of four hazard lights. when i push in the hazards my front passenger blinker works but none of the others. Could this all be due to a relay switch? Any ideas would be appreciated.
Old 02-05-2011, 06:01 PM
wow im surprised that there are no suggestions! Never had that happen on a forum
Old 02-05-2011, 06:07 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Be patient. It's the weekend and a lot of folks are out doing things besides hanging out here. I'm sure someone will chime in here shortly to help you out.
And, Welcome to FTE!
Old 02-05-2011, 07:38 PM
carltonwebb's Avatar
carltonwebb carltonwebb is offline
carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.
I would say multi function switch (turn signal assembly) . There is a procedure to check it in my photos. Click below
Ford Truck Enthusiasts Forums - carltonwebb's Album: Random - Picture
Rear brake lights go through multifunction switch. 3rd brake light comes off a direct splice from switch on pedal.
U did not say if gas or diesel.....With third brake light working and if multifunction switch is ok, I would check the following connectors.
If diesel, under the aux relay box under hood is a round 8 pin connector. There are 2 that look really similar...Check this for corrosion.
If gas, its basically in the same place but square with 12 pins. The splice for the trailer lights is after this connection so its the 1st place to look for problems going by your description imho.
Old 02-05-2011, 11:19 PM
ak-angler's Avatar
ak-angler ak-angler is offline
ak-angler has a good reputation on FTE.ak-angler has a good reputation on FTE.
Did you check the fuses?
Old 02-06-2011, 06:10 AM
its a gas v8 and Ive checked the fuses that I believe would have been the issue. all are good. Ive also looked under the hood on the drivers side and found to black boxes with relays in both and have pulled them out and looked them over. no corrosion, however Im not 100% sure they are what Im supposed to be looking for. I dont think they had 12 pins. The multifunction switch Im assuming is in the steering column?? If so Ill have to look into that. thanks
Old 02-06-2011, 07:16 AM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Posting electrical problems in the electrical section would get you the fastest help since folks tend to hang out where their interests are highest.
Multi-function switch or it wiring connectors.
Pull the column shrouds and inspect.
Old 08-03-2014, 01:40 PM
rich1zoom rich1zoom is offline
rich1zoom is starting off with a positive reputation.
No brake lights. Problem solved. 2006 F250 Super Duty. My symptoms started when my truck was fairly new. I had an intermittent warning, TBC FAULT. After 115,000 miles I noticed that sometimes it was hard to get the shifter out of Park once in a while. Then the TBC Fault warning came on almost every time I hit the brakes. Somebody told me I didn't have brake lights including the third light. My flashers and turn signals worked correctly. I saw a goofy guy on You tube playing with his brake light switch located just above the brake pedal. Like him, when I physically turned the switch my brake lights came on. To remove the switch you remove a green safety cover from a clip, remove the clip, slide switch and pedal arm off and disconnect the harness. The only tool used was a small flat screwdriver. My part #F87Z-13480-AA cost just under $30 at the dealership.
Old 08-05-2014, 07:58 PM
Will104 Will104 is offline
Will104 is starting off with a positive reputation.
hey test the 2 wires closest to the firewall on your brake pedal position switch, one should be constant and the other should get power when you hit the pedal, if you are not getting power at all i would venture a guess its the module its getting and sending power i would move up to the multifunction switch
Old 08-06-2014, 07:17 PM
Thanks Will. I guess I didn't specify that replacing the brake switch fixed my problems. I took the old switch apart, there were three separate contacts. Obviously one is for the brake lights, another must activate the release for the shifter.
Old 03-02-2015, 11:34 PM
keg0177 keg0177 is offline
keg0177 is starting off with a positive reputation.
I've had this same "TBC Fault" for a while and it doesn't allow my signals nor brake lights to function. I've checked fuses and the trailer plug and I have yet to find any clear reason, other than get a new one. Has anyone found a way to bypass the TBC to allow functionality of signal lights and brakes lights?
Old 03-03-2015, 06:12 AM
Keg)177. Did you try the brake light switch located under the dash on the brake pedal arm ? That solved all my issues.
Old 03-03-2015, 07:03 AM
Just Strokin Just Strokin is online now
Just Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to behold
Here is the wiring charts...hope it helps
2004 Exterior Lights 1
2004 Exterior Lights 2
Old 03-03-2015, 08:42 AM
Quote:
The TBC isn't causing your problem. Your problem is a lack of brake lights. If you haven't checked the switch and its circuit yet, you're wasting everyone's time, including your own.
Old 03-03-2015, 02:38 PM
Rish1zoom, I did try that according to info I saw hear. I grabbed it directly and toggled it back and forth but it didn't actuate the brake lights at all
No brake light or hazards Keith Free 1978 - 1996 Big Bronco 4 09-04-2016 01:52 PM
Turn signals not working RileyCarroll 1973 - 1979 F-100 & Larger F-Series Trucks 6 07-21-2016 05:54 PM
brake light problems powerstrokeddiesel 1997 - 2003 F150 4 02-26-2016 09:40 AM
Let there be light... miihere24 1967 - 1972 F-100 & Larger F-Series Trucks 44 01-14-2016 01:32 PM
Running lights out, but brake and hazard work? RhinoScores 1978 - 1996 Big Bronco 2 04-25-2010 10:33 AM
Tags
04, 1994, 1996, 1999, 2000, 2001, 350, brake, expedition, f250, ford, hazards, lights, lignt, multifunction, taurus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
