Almost Bought the Farm
And i really dont want this to happen again. Last night the shaft that my pitman arm bolts to broke and I lost my steering. If it were not for the large pile of snow that stopped me I would have hit a telephone pole. What I would like to know is why this happend. Is it the lift that I put in this truck or was it all the beating I did on the stock pitman arm to get it off that caused this.
that my friend is a sector shaft. they take a lot of abuse from dealing with the leverage of tires, especially big tires. i think ford just dropped the ball on that part strength wise. i've seen two snap in person, and heard of a lot more. lucky for my buddy, his broke at 10mph leaving a bank drive through. he had 35's on an f250. mine broke in a ravine when a tow truck operator who didn't know how to use his winch pulled my truck in the wrong direction with the front axle being stuck in ice. it actually worked out in the long run for me, because after i looked at the broken pieces i could see rust inside where it sheered across meaning that it was broke already and just waiting for a load to finish the job.
i'd say the cause is just general wear and tear. check yours out, and see if you can notice any signs of a previous crack with some rust/oxidation in there. it was plain as day on mine. just glad it broke where it did and not while going down the highway.
EDIT: dually front axle with srw rims joe.
Received 3,100 Likes
on
F-superduty is a f-450 before they started calling them that, and basically are cab and chassis trucks with different springs, but most of the other parts are the same.
I've never heard of a sector shaft breaking, but I'm not an off-roader. Perhaps the reason you guys have had them break is bigger wider tires, high lifts, and beating the hell out of them.
i kind of wanna start some stuff with this guy from the name alone, and then there is the fail he brought with him.
rangers, no. go fly a kite pal.
did my own research today on the light duty trucks and they do share the same box from f-150 to 450. kind of sad really. i'll check on the big trucks eventually.
you should go cut your nuts off and start over with a new username because i was not impressed.
