1948-1960 projects updates
You can't shift on the fly so you need to either start in high or low.
He's got it turned around to make it an overdrive. In its regular position the transfer case is 1:1 in it regular position, and 2:1 in low range. By turning it around you get 1:1 and in low range 1:2, the opposite of its regular position. This turns it into an overdrive instead of and underdrive. I just wonder if this will affect oiling inside, cause certain tranny's or gear drives rely on certain rotation for oiling of the gears
I am getting a stock frame so i can do a frame up(darkside) style...i have changed many hoses,steering box and a temporary wood floor.
[quote=F250racer;9932057]I'm using it as a doubler/overdrive, not a splitter.quote]
It took me a while for it to sink in, but now I understand how it works. You also said you are using a styleside bed with flares. Are you planning on cutting out the fenders on the bed and adding flareside fenders to clear the wheels? Just curious. I like your truck, very cool!
I plan to just pick up a set of fender flares from a 4x4 shop or one of those towing supply shops and just bolting them on, should be pretty easy to find ones that match the bed pretty close, they shape/lines really haven't changed much between '59 up to the '90s
Seat Upholstery
I worked on the seat this weekend. I'm installing a firewall mounted brake master cylinder/pedal assembly, and an Ididit steering column. The suppliers all said to put in your seat first to position everything correctly, so I'd better get going on the seat. I decided re-upholster the stock seat. Here's the progress:
"Before"
Original stuffing - complete with rat's nest
Here's the frame....springs fixed and painted:
New backing and modern foam padding:
And...here's the seat bottom. I'll have to work on the seat back later this week:
More to follow!
Dan
"Before"
More to follow!
Dan
