2011 F-150 5.0L Aftermarket Exhaust - Ford Truck Enthusiasts Forums
Old 02-04-2011, 05:07 PM
640 CI Aluminum FORD 640 CI Aluminum FORD is offline
640 CI Aluminum FORD has a great reputation on FTE.640 CI Aluminum FORD has a great reputation on FTE.640 CI Aluminum FORD has a great reputation on FTE.640 CI Aluminum FORD has a great reputation on FTE.640 CI Aluminum FORD has a great reputation on FTE.
Hey guys, Just found this vid on Youtube, Don't know if anyone here, has an aftermarket exhaust on their 2011's yet, But I found this of the 5.0L It sounds really good to me! A little different from the 5.4L
(2011 5.0L Borla Exhaust)
YouTube - Borla R&D - 2011 Ford F-150 - ATAK Cat-Back Split-Rear Exhaust
(2011 5.0L Flowmaster Super 44)
YouTube - 2011 F-150 5.0 Flowmaster Super 44
Old 02-04-2011, 06:38 PM
DJR 17's Avatar
DJR 17 DJR 17 is offline
DJR 17 is starting off with a positive reputation.
I liked the borla better, but maybe just cause the sound is crappy on the flowmaster clip. I can't wait to get a magnaflow on mine. I wonder if I'll gain anything other than more noise with it tho, the new design is pretty good?
Old 02-04-2011, 11:22 PM
Quote:
Yeah I liked the Borla better too. And your right, I wonder if these engine's will see and improvements as they already breathing good. I guess only time will tell.
I use to have an old 1990 F-150 with the old Pushrod 5.0L and I did the full exhaust treatment on it, True duel flowmasters, Headers, Single highflow Cat...The works, that truck gained almost 40hp from that alone. I doubt you'll see gains like that in these newer trucks.
Old 02-05-2011, 09:18 AM
Gary Atsma Gary Atsma is offline
Gary Atsma is gaining momentum as a positive member of FTE.
I got to dive under a 5.0 truck at my dealer w/ a tape measure. I didn't have a lot of time, but it looks like the headpipes are about 2.5", and the rest of the system including tailpipe is a full 3". I MAY be a bit off on the headpipe as I couldn't see the tape too well while checking it, but the rest IS 3". Being that just about all after market systems nowdays are 3" catback systems, I wonder if they'll go bigger, say, to 3.25 or 3.5", on the single pipe before the muffler, or if the 3" stock pipe is actually big enough to send 360HP worth of spent gases on their way.
Looks like this could be open to some speculation....
Old 02-05-2011, 09:29 AM
I agree that the sound reproduction of the Flowmaster is crappy, but I would never use a 44 or 40 series Flowmaster myself, as they are too loud for my tastes. A 50 series Big Block would be a lot mellower and flow just as well, and not be as obtrusive.
Old 02-05-2011, 04:18 PM
rockstate45 rockstate45 is offline
rockstate45 is starting off with a positive reputation.
That Borla does sound great.
I wonder what about the 5.0 is that gives it that raspy sound?
I have the Borla on my Tundra and it sounds amazing too, but definitely a different sound than the 5.0 F150
-rockstate
Old 02-05-2011, 06:18 PM
Quote:
I would say it's the state of tune that allows a 5.0L engine the ability to crank out 360HP. The variable cam timing feature allows for "radical" timing in the upper ranges, but "mild" timing in the lower ranges for a smooth idle. A little over-simplified, but basically true.
Old 02-05-2011, 06:43 PM
Very interesting.
If I were to buy a truck tomorrow it'd be a 5.0. Sweet truck and a sweet motor. I'm in it for the long haul in my Tundra though. Only 57ish k miles so it's still got some life left in it.
-rockstate
Old 02-05-2011, 07:51 PM
97flairside 97flairside is offline
97flairside is starting off with a positive reputation.
That flowmaster didn't sound to bad. The borla was to raspy for me.
Old 02-05-2011, 10:49 PM
Quote:
I have a feeling that ANY muffler is going to sound more raspy behind the 5.0 compared to other engines just because of its high state of tune AND the higher RPMs it can turn. Would any of us complain of this trait? Not me......
Old 02-07-2011, 12:54 PM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
I've heard the Borla & Flowmaster 44's in person...had the Flowmater 44's on my truck for 5 days....wne t back to what I have run on all my vehicles for 30 years...Allied,
Tone is deeper, much nicer rumble, flow is equal to either Borla or Flowmaster
Yeah, IMHO
Old 02-07-2011, 06:18 PM
Matts72's Avatar
Matts72 Matts72 is offline
Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.
Factory is good with me... I despise the Borla sound greatly... I never want to sound like that pile of garbage!
Old 02-07-2011, 08:00 PM
Quote:
I hate to say it, but that's the motor man. The stock 5.0 sounds very similar just a little muffled.
Listen to Borla on a C5 or a C6 Corvette... or a Mustang... or anything else and you'll just about cream yourself. I think it's one of the best sounding mufflers.
-rockstate
Old 02-07-2011, 08:48 PM
Jr.Ranger-04 Jr.Ranger-04 is offline
Jr.Ranger-04 is starting off with a positive reputation.
Very interesting.
-rockstate
What is your opinion of the tundra after 50K,how is the mileage, any significant problems to mention???
Old 02-07-2011, 09:14 PM
In my 57k miles, I had a new water pump at like 45-50k miles and a serpentine belt.
I've had my front diff rebuilt around 54k miles.
Air injection pumps are a multi-thousand dollar problem but can be bypassed at no charge... but you may need to pass inspection.
Honestly, the best things I"ve done to this truck is the Old Man Emu suspension up front, the ranch hand brush guard, tires and exhaust. The factory stuff is good, but everything else makes it better.
The powertrain is STOUT, and people over on the Tundra forums say it's better than the new Fords in races... personally I'd buy a 5.0 whether or not it's slower or faster. Not a big deal as they all offer plenty of power.
The sheet metal is weak, but I assume all trucks are now a days in the 1/2 ton market.
All in all, good truck but it leaves a LITTLE bit to be desired. Put me in the market today, and I'd probably buy a Ford but I"ve always been partial to Fords. The Tundra is a good truck and not to be discounted totally b/c it's "japanese."
The other thing is I have a very early first model '07. Might be a little bit more susceptible to problems.
If you go onto the Tundra boards you'll see what the majority of the problems are. Nothing TOO significant that affects the entire tundra population except the air injection pumps.... mechanically. All of them have thin sheetmetal, poor paint, etc... but what car doesn't htese days?
-rockstate
2013 F150 5.0 - Flowmaster American Thunder flowgoode Exhaust Systems 3 10-10-2013 01:48 AM
2012 5.0L vs 2011 Ecoboost (Drag Race video clips!) 640 CI Aluminum FORD 2009 - 2014 F150 68 04-17-2013 09:08 PM
''VIDEO'' 2011 F-150 5.0L vs Tundra 5.7L Drag Race 640 CI Aluminum FORD 2009 - 2014 F150 44 07-24-2012 03:37 PM
Another reason why I want a Ecoboost! skidooman Manitoba / Saskatchewan Chapter 69 10-31-2011 11:25 AM
Some video clip candy for us 5.0L owners! 640 CI Aluminum FORD 5.0L Coyote 4 09-22-2011 01:13 AM
Tags
2011, 2011f150, 50, 50l, aftermarket, borla, engine, exhaust, f150, ford, market, muffler, performance, systems, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
