Type of Brake Fluid - Ford Truck Enthusiasts Forums
Type of Brake Fluid
Old 02-04-2011, 06:01 PM
creich68's Avatar
creich68 creich68 is offline
creich68 is gaining momentum as a positive member of FTE.
Type of Brake Fluid
Well my dad has a 2010 XLT 2WD with the 4.6 3V. The other day, after the snow storm, he had to put chains on the back to get out of the driveway (big hill covered in ice). As he drove around about 1.5 miles roundtrip, one of the chains got some slack in it and tore a brake line. He has a new brake line but needs to bleed the lines. Unfortunately I'm about 100 miles away and he doesn't have access to his owners manual at the moment. Does anyone know what type of brake fluid it needs? I have Dot 3 in the shop for him, but i'm afraid it may need Dot 4 or 5. Any advice will be much appreciated. Thanks!
EDIT: No results show up in a search
Old 02-04-2011, 10:00 PM
juneau76's Avatar
juneau76 juneau76 is offline
juneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud of
It's DOT 3. Page 400 of the manual found here: http://www.motorcraftservice.com/vdi...&VEHICLE=F-150
Old 02-05-2011, 11:04 AM
creich68's Avatar
Quote:
Thanks a bunch!
DOT5 Brake Fluid jonmammenga 1973 - 1979 F-100 & Larger F-Series Trucks 1 11-17-2014 10:15 PM
Dot 4 brake fluid senix Crossovers 7 10-24-2014 03:41 PM
Need clarification for power steering flush bigred66 6.0L Power Stroke Diesel 3 06-24-2014 08:51 PM
Brake bleeding ? Nice Work Truck 6.0L Power Stroke Diesel 16 10-26-2009 12:44 AM
Dot 3 Or Dot 4 Brake Fluid SAWDUST 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 06-04-2005 06:51 PM
Tags
1979, 1997, 2002, 2003, 2007, 2008, 2009, brake, f150, f250, flugid, fluid, ford, truck, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
