1966 F100 Transmission Repair or Swap
Old 02-04-2011, 02:57 PM
gcashs66's Avatar
gcashs66
gcashs66 is offline
I have a 1966 F100 with a FoMoCo C5AR 7006 C, 3 speed (no OD), column shift transmission in need of new bearings. I need to either replace the bearings or replace the transmission.
Is there a direct fit 3 or 4 speed floor shifter I can drop in that would only require a hole in the floor for the shifter?
Or, are parts available for the rebuild. I have not found any good sources for a rebuild kit.
Also, how hard is it to rebuild this tranny?
Thanks for your help.
Old 02-04-2011, 03:10 PM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
Try these guys for parts. I've been buying parts from them for over 40 years......
Transmission Exchange Co - Google Maps
Old 02-04-2011, 05:47 PM
biggut's Avatar
biggut
biggut is offline
The old t18 granny-gear 4 speed is a bolt-in option. They should be easy to find in the wrecking yard (I've got 2 of them laying out in my yard). They are nearly bullet-proof, and should last for years.
Old 02-04-2011, 06:01 PM
ddavidv's Avatar
ddavidv
ddavidv is offline
Good grief, those 3 speeds are in everyone's shed. I know a guy who has one by me (Hershey, PA) he'd love to get rid of. The problem is they are not cost effective to ship.
I can't imagine they are difficult to rebuild. The MOTOR repair manual for that vintage does cover teardown of the trans. Other than a few things like the seals for the selector shafts not being readily available I had no trouble finding parts for mine at NAPA (new seals) when I did the clutch.
Old 02-04-2011, 06:39 PM
gcashs66's Avatar
gcashs66
gcashs66 is offline
ddavidv
If your friends tranny is in reasonable condition, I'd be interested in helping him get rid of it.
Thanks to you other folks for your suggestions. I'll check them out.
Old 02-04-2011, 07:33 PM
Broomfieldbum's Avatar
Broomfieldbum
Broomfieldbum is offline
I don't know where you are, but one of the guys on here told me he could rebuild a 3 speed for about $375. PM if you want more info.
Personally I have a love hate relationship with the 4 speed 3 speed argument. I like 3 on the tree because very few people can drive them, but another gear would help. Not to say many 4 speeds give you a higher top end.
Old 02-04-2011, 10:31 PM
gcashs66's Avatar
gcashs66
gcashs66 is offline
Broomfieldbum,
I'm in SoCal. Where is he?
Old 02-05-2011, 12:14 AM
Broomfieldbum
The guy who offered is here in Denver. He said he would hot tank the case sharpen the gears and put new seals and bearings. Make it just like brand new. I would think you could find someone in SoCal who could do the same.
Old 02-05-2011, 04:54 AM
jowilker's Avatar
jowilker
jowilker is offline
Bum, The 4 speed adds to the low end, all trannys that are not over or under drive have a 1 to 1 output ratio, 3, 4, 5, 6 doesn't matter.
It's the rear gear ratio that makes the difference.
John
Old 02-05-2011, 07:35 AM
ddavidv's Avatar
ddavidv
ddavidv is offline
Shipping to CA would cost more than the trans. I'm sure you can find one closer to home.
Old 02-05-2011, 09:04 AM
SixtySix Ford's Avatar
SixtySix Ford
SixtySix Ford is offline
Truck fright on a tranny would probably be less then 75 bucks to Denver.
Im also the member that Broom is talking about that can rebuild these trannys. And I offer a 2 year Warranty with the full rebuild. For 375 to 400 depending on what it may or may not need.
Old 02-05-2011, 09:46 AM
ajcal225's Avatar
ajcal225
ajcal225 is offline
www.freightquote.com
I had front and rear dana 60's shipped cross country for $150.. I'm sure they could do the trans very cheap.
Old 02-05-2011, 10:29 AM
gcashs66's Avatar
gcashs66
gcashs66 is offline
Sixty-Six,
I'll check on shipping.
Everything here in CA is more expensive. I like the idea of a FE guy doing the work.
Old 02-05-2011, 01:37 PM
SixtySix Ford
Originally Posted by gcashs66
Sixty-Six,
Ok thats fine with me. Please check your PMs as Im not sure I can post prices and stuff in open forum.
John
Old 02-05-2011, 03:17 PM
OldHarley's Avatar
OldHarley
OldHarley is offline
Not sure who's thinking about converting to what, but those 4 speed granny tranny trucks had a higher/taller hump.
Quick Reply: 1966 F100 Transmission Repair or Swap
