1966 F100 Transmission Repair or Swap - Ford Truck Enthusiasts Forums
Old 02-04-2011, 02:57 PM
gcashs66 gcashs66 is offline
gcashs66 is starting off with a positive reputation.
I have a 1966 F100 with a FoMoCo C5AR 7006 C, 3 speed (no OD), column shift transmission in need of new bearings. I need to either replace the bearings or replace the transmission.
Is there a direct fit 3 or 4 speed floor shifter I can drop in that would only require a hole in the floor for the shifter?
Or, are parts available for the rebuild. I have not found any good sources for a rebuild kit.
Also, how hard is it to rebuild this tranny?
Thanks for your help.
Old 02-04-2011, 03:10 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Try these guys for parts. I've been buying parts from them for over 40 years......
Transmission Exchange Co - Google Maps
Old 02-04-2011, 05:47 PM
biggut's Avatar
biggut biggut is offline
biggut is starting off with a positive reputation.
The old t18 granny-gear 4 speed is a bolt-in option. They should be easy to find in the wrecking yard (I've got 2 of them laying out in my yard). They are nearly bullet-proof, and should last for years.
Old 02-04-2011, 06:01 PM
ddavidv's Avatar
ddavidv ddavidv is offline
ddavidv is gaining momentum as a positive member of FTE.
Good grief, those 3 speeds are in everyone's shed. I know a guy who has one by me (Hershey, PA) he'd love to get rid of. The problem is they are not cost effective to ship.
I can't imagine they are difficult to rebuild. The MOTOR repair manual for that vintage does cover teardown of the trans. Other than a few things like the seals for the selector shafts not being readily available I had no trouble finding parts for mine at NAPA (new seals) when I did the clutch.
Old 02-04-2011, 06:39 PM
ddavidv
If your friends tranny is in reasonable condition, I'd be interested in helping him get rid of it.
Thanks to you other folks for your suggestions. I'll check them out.
Old 02-04-2011, 07:33 PM
Broomfieldbum's Avatar
Broomfieldbum Broomfieldbum is offline
Broomfieldbum is gaining momentum as a positive member of FTE.
I don't know where you are, but one of the guys on here told me he could rebuild a 3 speed for about $375. PM if you want more info.
Personally I have a love hate relationship with the 4 speed 3 speed argument. I like 3 on the tree because very few people can drive them, but another gear would help. Not to say many 4 speeds give you a higher top end.
Old 02-04-2011, 10:31 PM
Broomfieldbum,
I'm in SoCal. Where is he?
Old 02-05-2011, 12:14 AM
The guy who offered is here in Denver. He said he would hot tank the case sharpen the gears and put new seals and bearings. Make it just like brand new. I would think you could find someone in SoCal who could do the same.
Old 02-05-2011, 04:54 AM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
Bum, The 4 speed adds to the low end, all trannys that are not over or under drive have a 1 to 1 output ratio, 3, 4, 5, 6 doesn't matter.
It's the rear gear ratio that makes the difference.
John
Old 02-05-2011, 07:35 AM
ddavidv's Avatar
Shipping to CA would cost more than the trans. I'm sure you can find one closer to home.
Old 02-05-2011, 09:04 AM
SixtySix Ford's Avatar
SixtySix Ford SixtySix Ford is offline
SixtySix Ford is starting off with a positive reputation.
Truck fright on a tranny would probably be less then 75 bucks to Denver.
Im also the member that Broom is talking about that can rebuild these trannys. And I offer a 2 year Warranty with the full rebuild. For 375 to 400 depending on what it may or may not need.
Old 02-05-2011, 09:46 AM
ajcal225 ajcal225 is offline
ajcal225 is starting off with a positive reputation.
www.freightquote.com
I had front and rear dana 60's shipped cross country for $150.. I'm sure they could do the trans very cheap.
Old 02-05-2011, 10:29 AM
Sixty-Six,
I'll check on shipping.
Everything here in CA is more expensive. I like the idea of a FE guy doing the work.
Old 02-05-2011, 01:37 PM
Quote:
Originally Posted by gcashs66 View Post
Sixty-Six,
Ok thats fine with me. Please check your PMs as Im not sure I can post prices and stuff in open forum.
John
Old 02-05-2011, 03:17 PM
OldHarley's Avatar
OldHarley OldHarley is offline
OldHarley has a good reputation on FTE.OldHarley has a good reputation on FTE.OldHarley has a good reputation on FTE.
Not sure who's thinking about converting to what, but those 4 speed granny tranny trucks had a higher/taller hump.
66 f100 Needing a new Steering Column.....HELP!! DoubleJ 1961 - 1966 F-100 & Larger F-Series Trucks 8 11-12-2015 09:14 AM
I need another gear! Texasknowhow 1967 - 1972 F-100 & Larger F-Series Trucks 36 01-03-2015 10:55 AM
3-speed Shifter Linkage ratrod1923 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 06-30-2014 02:22 PM
Steering Column for 1966 F100 ksteen 1961 - 1966 F-100 & Larger F-Series Trucks 4 03-02-2010 07:17 AM
62 F100 floor shifter jethrob 1961 - 1966 F-100 & Larger F-Series Trucks 3 09-18-1999 09:04 AM
Tags
1966, automatic, c5ar7006c, f100, floor, ford, fordtruck, manual, repair, repairing, shifter, swap, transmission, transmissions, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
