89 Fluctuating Idle
89 Fluctuating Idle
I have an 89 Ford F150 4.9 that when idling the RMP's go between about 1500 down to about 500 and back up and back down. I cant seem to get a wrench on the idle adjustment screw but I think this wouldn't fix the problem anyway. Does anyone know what could cause this?
Truck Information:
1989 Ford F150 Custom 4.9L Inline 6-Cylinder 300 4x4 Manual Locking hubs 4 speed(1 = granny) 8-ft bed and standard cab. Fed. Emissions.
Truck Information:
I took a loog at the vaccum hoses and i will take a deeper look.
Thank you guys, I'll get back to you.
Some good info in this thread: https://www.ford-trucks.com/forums/1...code-53-a.html
The Idle Air Control (IAC) is also well known to cause idle issues. Cleaning or replacing it has been a common fix as well. A hunting idle like yours could be a combination of sticky IAC and a vacuum leak(s).
Truck Information:
Truck Information:
A sticking or stuck IAC will not typically trigger a Check Engine Light. A TPS that has a dirty internal wiper will not necessarily trigger a CEL either. As long as the closed throttle output signal falls within 0.6-1.0VDC the PCM will be happy. A TPS with a dirty/bad wiper will output a signal of varying amplitude every time you move the throttle. Because of the ratchet function built into the PCM programming it is always looking for the minimum output signal then re-adjusting based on that input. When the TPS returns to a somewhat normal state, the PCM thinks the throttle is open more than it really is so it increases the duty cycle to the IAC which in turn increases the idle RPM.
What was the closed throttle value? Did you open the throttle slowly while watching the output signal? Were they are indications of a bad spot on the wiper?
How did you check for vacuum leaks before? the visual and carb. cleaner spray method are not always the best way to find leaks. I use a hand held vacuum pump/gauge to test each circuit.
